| Snowflake |
11-26-2015 08:32 PM |
Originally Posted by MeAndMyToys
(Post 1032808)
He said he wasn`t moving it, it was in the hangar and he was sitting in it playing with the avionics.
Oops, you're right. I missed the reply with that detail. If it just closed while sitting there, then maybe there *is* a problem with one of the pistons?
I know i've seen the piston part numbers posted here on VAF in the past, and people have posted the next size up in piston as well, which has a little more force. Personally I don't think you need more force over the stock piston, the stock one works great when it's working the way it should.
