VAF Forums
-   Glass Cockpit (https://vansairforce.net/community/forumdisplay.php?f=35)
-   -   Garmin?s new GAD 27 interface module pairs with G3X? Touch to streamline (11/18/15) (https://vansairforce.net/community/showthread.php?t=131698)
g3xpert 10-17-2016 12:33 PM
Originally Posted by tgmillso (Post 1119089)
If I have an alternator failure and shed pretty much all loads except my G5 and Aera 660 (i.e. I turn off my G3X) but keep power to the GAD 27, am I still able to operate the flap and more the trim if they are wired through the GAD 27?
Thanks.
Tom.
Hello Tom,
We responded directly via email to your "keep alive" question.
For this question, yes even if you power down the G3X Touch displays, ADAHRS, engine interface, etc and keep the the GAD 27 powered, it will still respond to the flap and trim switches and drive the trim and flap motors in a manual mode.
Steve
tgmillso 10-17-2016 10:42 PM
Excellent. Thanks Steve. Much appreciated.
Tom.
Kentsrv7a 10-18-2016 08:14 PM
GAD 27 keep alive
G3Expert please post the answer to the GAD27 power question about the keep alive circuit. I am installing the system as well and have wondered about the same question.
Thanks!
g3xpert 10-19-2016 04:38 AM
Thanks!
Hello Kent,
The most common way to power the PFD (GDU 4XX), ADAHRS (GSU25), and Engine Monitor (GEA24) in a system using the GAD27 conditioned power (keep alive) output is to wire the Power 1 pins on each to the aircraft main power bus and the Power 2 pins on each to the GAD27 conditioned power output.
When this is done, main bus voltage drops which occur during engine cranking will not affect the PFD/ADAHRS/Engine Monitor which are up and running before starting the engine. This, of course, also maintains the GPS fix that the PFD may have already established before you started the engine.
Let us know if you have additional questions.
Steve
Kentsrv7a 10-19-2016 08:07 AM
Steve, Thanks for the post!
ppilotmike 10-19-2016 10:07 AM
Thanks Steve
Very informative Q & A session. Much appreciated.
N834ST 07-04-2017 05:24 PM
I am retrofitting the G3X into my RV-7. Is there a way to use my current trim/flap position indicators as well as the G3X? Not sure how I would wire it with regard to the +5v from the GEA 24.
Anyone done this?
Thanks!
supik 09-28-2017 11:50 AM
Vans Flap Positioning System
I am about to order the RV-10 Fuse Kit and would like to go with GAD27 to operate the flaps. Will I need the FLAP POSITIONING SYSTEM from Vans?
Thanks!
Kentsrv7a 09-28-2017 12:31 PM
Nope! The GAD27 will do it for you. What you do need is a flap position indicator to show you where the flaps are positioned on the G3X screen. I used a Ray Allen POS position indicator to do the job. Works great!
supik 09-28-2017 04:22 PM
Kent, many thanks for your speedy reply!
