VAF Forums
-   COMM (https://vansairforce.net/community/forumdisplay.php?f=38)
-   -   430W Com Needs Service Message (https://vansairforce.net/community/showthread.php?t=131192)
Darren Kerns 11-01-2015 07:05 PM
Guys
I was out flying tonight & my 430W had a message flashing.
When I pushed the Message button it said Com Needs Service.
I read my owners manual it said Transceiver needs service. It said I may still be able to transmit. I was talking to another plane tonight so it is working.
Calling avionics shop tomorrow.
Any thoughts & ideas would be appreciated.
Darren Kerns
RV7 N599DT
boom3 11-01-2015 10:52 PM
If it's out of warranty I'm guessing you'll be looking at Garmin's flat repair rate of $900. :(
Darren Kerns 11-02-2015 05:21 AM
Jeff
This is bad news I really did not want to hear this morning!!
I cannot win for losing.
Thanks for giving me a heads-up though.
Darren Kerns
RV7 N599DT
Paul K 11-02-2015 07:30 AM
Try this first! I had the same issue and after trying every wiring solution, it was suggested I slide the unit out of the tray and then put it back in. Sounds silly but it worked! Must have been a bad connection.
larrynew 11-02-2015 09:19 AM
My 430W was jumping frequencies. The advice I got and took was to remove the top cover, gently brush every surface I could reach, unseat and reseat every connector I could, rebrush and reassemble. I thought I had been careful during the build but I found a small amount of aluminum dust inside. It's worked perfectly for the last 100 hours.
Ironflight 11-02-2015 09:55 AM
I wouldn't despair until you get the message several times, or it won't go away. I have seen that once or twice in ten years of flying with a couple of 430W's, and never sent anything in for servicing. I'd bet on a momentary low voltage condition - cycle the circuit breaker a couple of times reseat the unit - maybe check for debris as Larry suggests. But if it doesn't come back...I wouldn't send it in.
DaleB 11-02-2015 10:07 AM
Aluminum dust, regular dust, dirt, tarnish, corrosion, oil, all kinds of things can cause intermittent connection issues that are often cured by just a simple re-seat. The contact wiping action takes care of a lot. I spent a couple of decades or more fixing computer equipment; re-seating cards and connectors fixed an amazingly large percentage of problems on everything from PCs to mainframes. The "Pink Pearl" pencil eraser was a valuable part of nearly every electronic technician's tool kit.
Darren Kerns 11-02-2015 10:48 AM
Thanks Guys for the advice & suggestions. I called Ron Collins Electronics and they thought the same thing. I need the databases updated as well too so I am going to fly it down there.
They seem to think it is an easy fix. I am not a pro like all of you guys are and I want a professional set of eyes looking at it.
I am just hoping the fog burns off so I can get down there.
Again, thanks guys for helping me. I really appreciate it!!
Sincerely,
Darren Kerns
RV7 N599DT
Darren Kerns 11-02-2015 05:40 PM
Update
Had my 430W looked at by John at Ron Collins.
John is a class act. The 430W worked perfectly on way down.
He pulled & tested it. Everything checked out good. He thinks it could have been a seating problem in tray. Updated it & was back in air.
Great service by a great guy.
Darren Kerns
RV7 N599DT
