| Canadian_JOY |
10-21-2015 08:31 PM |
Originally Posted by ccrawford
(Post 1023525)
Thanks for continuing this discussion.
For the AN fittings, is it normal practice to skip the thread sealant because the flare is there to create a "mechanical" seal and there is a concern that any sealant could cause those two flared/beveled surfaces from completely sealing?
Cory - it is indeed standard practice to not apply any form of sealant to AN flared fittings. The mechanical design of the flared fitting ensures tight metal-to-metal contact between the female flare of the pipe and the mating beveled surface of the male fitting.
The only "sealant" which may be used on flared fittings is a thin, soft aluminum flared fitting washer, referred to in the Spruce catalog as "DEL 37 degree fitting seal". This thin aluminum material is essentially compressed between the flared tube and the AN fitting. In doing so, it allows a good seal to be made in the event the male or female portion of the flare is marred by some minor imperfection such as a scratch.
Again, just to be clear, thread sealant of any sort (liquid, paste, tape) is not applied to AN 37 degree flared fittings.
