VAF Forums
-   Traditional Aircraft Engines (https://vansairforce.net/community/forumdisplay.php?f=21)
-   -   fly off period for engine prop combo? (https://vansairforce.net/community/showthread.php?t=1306)
JCN247DE 04-21-2005 08:30 PM
Hi group,
I have an aerosport power O-360 and Hartzell prop combo on my 7A. Any way of getting around the 40 hr fly-off period with this combo?
The feds are telling me if it ain't lycoming or continental... it's 40! The aerosport engine is built up with Superior components.
Jeff
Rosie 04-22-2005 12:40 AM
The feds are telling me if it ain't lycoming or continental... it's 40! The aerosport engine is built up with Superior components. Thanks, Jeff
Unless you can point the Feds (or AB-DAR) to a certificated plane flying the same Aerosport Power O-360 and Hartzell prop, it will be 40 hours :eek: Rosie
Mel 04-22-2005 05:57 AM
Rosie is right. The AeroSport O-360 is not a certificated engine.
Mel...DAR
N941WR 04-22-2005 06:20 AM
What about...
A Lycoming with a non-certified prop? Such as the one I'll have on my Lycoming O-290 D2 powered RV-9.
It is my understanding this will put me into the 40 hour fly-off requirement as well. Not that I mind, it will give me 40 hours to learn how to fly the thing before the pressure is on to give rides to family, friends, and other builders.
Mel 04-22-2005 06:34 AM
To qualify for a 25 hour fly-off 1/ the engine must be certificated, 2/ the propeller must be certificated, and 3/ the engine/propeller combination must be certificated. Anything other than that gets you a minimum of 40 hours. Also any aftermarket mods such as electronic ignitions and fuel injection systems not certified with your particular combination will not get the 25 hours.
Mel...DAR
