VAF Forums
-   RV-8/8A (https://vansairforce.net/community/forumdisplay.php?f=6)
-   -   Titan Throttle body inlet to RV-8 Snorkel (https://vansairforce.net/community/showthread.php?t=129947)
DMFenster 09-23-2015 10:59 PM
Have a Titan IOX-360. In reading the Manual that came with it - on page 14 there is an adapter that Titan sells that will adapt the snorkel to the throttle body. It is a flex hose. Anybody using this set-up - and how's it working out?
Also, none of the paperwork that came with the engine tells me things like plugs, oil filter, service intervals, etc. Is everyone just using the lycoming service intervals and the plug/filter manufactures recommendations.
Dave
RV-8
Robert Anglin 09-24-2015 07:17 AM
No.
No, but a short cut is to just fab. one. 3/16" flat plat and a peace of tail pipe, Tig or welded together and your there. We also used the blue hi-Temp silicone hose from a ford V-8 diesel and their band clamps as well. Works very well. You will want to make a small bracket to hold the snorkel outlet end to the bottom of the crank-case as well. That will keep vibration cracking of the fiberglass snorkel down. Hope this helps, Yours, R.E.A. III #80888
clam 12-10-2016 10:26 AM
I am a little hung up at what I hope is the final junction in the air intake system, with the following components:
-Titan IOX-360 with horizontal cold air sump with 7 degree face
-Silverhawk fuel servo
-Van's RV-8 snorkel to left baffle ramp air filter
Specific area up for debate is the connection from the snorkel to the adapter. I have some ideas, none of which I think are ideal, so I'm soliciting inputs. The wooden template is temporary to locate servo centerline.
The obvious solution to bolt snorkel direct to servo is a no-go because the 7 degree face of the sump puts the snorkel way up into the alternator and leans it aft behind the filter area. I have already performed surgery once at the top to get the filter mounted, and I will rejoin the section after this end is solved. You can just see where the snorkel top has been cut off in the top right of last photo.
My search efforts landed most closely at this thread.
Thanks for any suggestions.
DanH 12-10-2016 01:19 PM
Sometimes you get to earn the title "airplane builder".
Seriously, there is nothing sacred about that piece of fiberglass. If the factory snorkel doesn't fit your system, throw it away and build one that fits. It's no harder than building any other duct.
http://www.vansairforce.com/communit...ad.php?t=44856
clam 12-10-2016 04:41 PM
thanks dan. i have read this, and many of your other works, with great interest. just thought i'd see if someone has a "magic widget" connector before i begin yet another deviation project on my project.
Robert Anglin 12-10-2016 06:13 PM
Dan is the Man
Dan is correct, you can cut and shape the fiberglass as you need to. We have an ECI throttle body it has the round face to the front that you just slide the hose over. What we did was fab an item much like the one you have in your hand in these pictures. It has a little thicker flange plate. We bolted it to the flange of the fiberglass and used a little RTV to seal it. I can just make out the down angle of your flange and understand your concern. I would be tempted to make a second flange to bolt to the fiberglass and put a peace of hose and a clamp on both sides. A nice gap between the lips maybe 3/8-1/2" and the hose would flex to take up the 7* offset. Just a thought, but Dan is right, some West systems epoxy and a little S cloth will do it also.
rv8ch 12-15-2016 06:33 AM
Dan makes it look so easy!
I'm staring at my air intake system now - I have the airflow performance FM-200 with a round connector, and wow - not quite as easy as Dan makes it look!
Starting to cut foam, glue it together, and shape it. Following Dan's detailed instructions to the letter, so in a couple of months I'll let you know how it works out.
After an hour of sanding, I'm ready to plunk down the $1400 that Rod Bower wants for his system. Nah, I need to learn this stuff.
vfrazier 12-15-2016 12:42 PM
Blake has these intake adapters, commonly used on the Rocket's forward facing Bendix servo.
http://cdn3.volusion.com/glckw.nxstp...jpg?1384102083
http://www.flyboyaccessories.com/Fue...ter-p/2103.htm
gyoung 12-15-2016 06:18 PM
You don't have to build the whole thing. When I fitted to my first RV it had the AFP servo with the round inlet. I whacked off the end of the snorkel with the Bendix flange and used foam, clay and mold release to fashion an end with a press fit to the servo.
I reused it on the rebuild but a different sump changed the servo position. Chopped it in half and with a few creative cuts and filler rejoined it to work again. Nothing is forever with fiberglass.
crabandy 12-15-2016 09:23 PM
That's the spirit, it's just fiberglass!
rv8ch 12-16-2016 06:51 AM
good idea
Originally Posted by gyoung (Post 1134652)
You don't have to build the whole thing....
That's a good suggestion. I also ordered a 3.25" 90 degree silicone elbow which I might use to help fit the throttle to my abomination. So far I'm enjoying sniffing polystyrene insulation dust. :D
