How to trim the Ego!!
Well it was a fine Saturday morning, tail kit inventoried, time to start the first job. Simple enough read and reread, match drilled the doubler plate to the forward vertical spar .... looking good.... reread to make sure I had it on the right side. reread then promptly countersunk the holes on the plate the wrong way.... congratulations I said to myself !!! Anyway easy enough plate to remanufacture.
By lunchtime Sunday had the vert stab ready for riveting .... the rivets on the rear spar started to look so much better when you wind the air pressure down from 100 psi to 40 I notice!!...... great kit. |
I reordered parts within the first section too. Now making really good headway on the fuselage with a pair of wings and tail ready to attach to something. You'll make stupider mistakes if you are anything like me.
Good luck with the rest of the build. |
Riveting
My build table had 2 air outlets, after a year I re plumbed table and added a small regulator & 3rd outlet for the rivet gun. Big convienence factor not having to back and forth to the compressor to adjust pressure, should have done this in the beginning.
Don B. RV 9 Rebuild in Progress. |
How to trim the ego
Smart thinking cajunwings can't beat being well organised.... now where did those cleco pliers go.... %$^#
Thanks for the encouragement HeliCooper, just a question though, about to slide the vert skin into place an start bending a few rivets and I notice there are no nut plates for the fairing between the where the plans say leave open for screws on the bottom rib. Did you work this out? |
I use a small inline regulator at the tool end of the air line.
Under Pressure
Here is a table of recommended air pressures. Before using them, make sure they work with your gun and compressor.
How to trim the ego
Thanks Bill and Miles I brought a brass regulator for the end of the gun. It has 1 to 6 incements on it but doesnt seem to make any difference.
Bill thank you for the pressure chart that will help and congrats on getting your project finished. Also having trouble with the Avery rivet squeezer, the bits that came with it dont adjust the clearance so I transferred the adjustable rod from the hand squeezer. Squeezed one rivet and now it doesnt deliver any power at the end of the stroke. So I put it in the healing corner with a couple of empty cans of beer to keep it company. |
Best wishes with your build! |
salto
Thanks Chris and all the very best with your build. Vans did a great job with customer service and packing the kit. It all arrived like it had just left the factory. I am really apprieciating the way the parts fit together.
| All times are GMT -6. The time now is 04:45 AM. |
