VAF Forums
-   -   Replacement 9A nose gear leg (https://vansairforce.net/community/showthread.php?t=129805)
C-GTDP 09-20-2015 10:11 AM
Tough landing in a cross wind on the weekend caused a slightly bent nose gear leg, blown tire, torn up fairings... and a bruised ego...
Firewall forward still requires a full thorough inspection, but I plan to replace every part and piece of hardware from the leg on down at a minimum, even though right now it looks like the leg took the worst of it. My question initially is, it appears that Vans sells the leg undrilled, first, does anyone know if this is true? Pretty sure my original was drilled (maybe it was factory match drilled to the engine brkt?). And if so, anyone have the best way to get the right sized hole in the right place? Hoping that I don't have to match drill to the existing engine brkt. Either in place or removed. I was hoping I can take to a machine shop with my existing leg and duplicate? I plan on talking with Vans on Monday but since it's the weekend thought I would toss it out. Also, anyone else with similar circumstances that wants to give me a heads up on what to inspect and look out for would be appreciated. Plane is 3 years old with ~500 (accident free till now) hours on it.
C-FAH Q 09-20-2015 10:36 AM
Check your email Russ.
plehrke 09-20-2015 10:39 AM
Send it to Vans to be matched drilled. You will have to send him your old gear. And he will send you a new one with matched drilled hole. He had us do that for the nose gear service bulletin SB 07-11-09. http://www.vansaircraft.com/pdf/sb07-11-9.pdf
Far North Texan 09-20-2015 10:47 AM
When I replaced mine, per the relevant service bulletin. I took it to the local machine shop, with the old gear, and they duplicated the hole. You can send it back to Van's but it's not necessary.
Of course if you end up getting a new engine mount you will need the new gear matched to the new engine mount but hopefully you don't need to do that.
bret 09-20-2015 07:27 PM
My 2010 finish kit leg came pre drilled. you can always go the taper pin route, that's what I will be doing.
C-GTDP 09-21-2015 10:45 AM
Case closed
Talked with the help desk this morning and it appears as if they started mass match drilling in 2005, so all nose gear leg to engine brkts after that time all match. They are sending me a nose gear leg predrilled, Certainly saves some work and grief.
