VAF Forums
-   ADS-B (https://vansairforce.net/community/forumdisplay.php?f=113)
-   -   ADS-B simplest compliance....?? (https://vansairforce.net/community/showthread.php?t=129802)
David-aviator 09-20-2015 08:05 AM
...this government mandate is coming and need to begin to the process to comply.
Have GRT Sport EFIS and Becker mode S transponder. What do I need to get this aircraft in compliance?
Thanks.
Bill.Peyton 09-20-2015 08:15 AM
Dave,
We can talk about it next week when we go to lunch. Which Becker transponder do you currently have?
Bill
David-aviator 09-20-2015 08:47 AM
Originally Posted by Bill.Peyton (Post 1015322)
Dave,
Bill
Bill,
Thanks.
This is the unit
https://www.aircraftspruce.com/catal...lickkey=213283
It has Becker blind encoder attached to it.
Walt 09-20-2015 10:14 AM
The Becker you have is a class 2 unit (low power) which is not approved for ADS-B out (class 1 is required).
jclark 09-20-2015 01:01 PM
Thanks.
Two paths are available to you. Neither has anything to do specifically with the GRT Sport. (I have three Sx's in my RV6).
UAT - a dedicated box/system that does everything (e.g. NavWorX)
1090ES transponder - Garmin (330ES) or Trig (TT-31 or TT-22).
++PLUS++
Certified position source - e.g. Garmin 430W, Garmin 650, newly released position source GPS from Garmin, or AviDyne (I think).
James
BobTurner 09-20-2015 02:04 PM
++PLUS++
James
If your Sport is an HX then it will remotely operate a Trig 22 box without the control head.
Only ADSB-out is required, but the -in is relatively inexpensive. Many UAT boxes include "in" (but not all); with the transponder route you need a separate "in" box. Be sure to get one that will display on the GRT.
There are several gps position sources that are less expensive than the full-up navigators (but not cheap).
Xkuzme1 09-20-2015 02:34 PM
Maybe not cheap, but easiest...
http://www2.l-3com.com/AviationProducts/
Mel 09-20-2015 03:33 PM
I think you will also need a "certified" GPS. The one in the Sport is not certified.
Walt 09-20-2015 04:23 PM
I sell the L3 NGT-9000 for $5895 with everything included. When you add up the price for a new transponder, certified GPS source and ADS-B receiver it's really very competitive.
It also has a very nice touch screen display that shows weather and traffic.
David-aviator 09-20-2015 05:01 PM
ADS-B 101.
Getting an education quick.
Thanks.
What is the compliance date before we are grounded without it?
