VAF Forums
-   ADS-B (https://vansairforce.net/community/forumdisplay.php?f=113)
-   -   ADS-B Out Compliance (https://vansairforce.net/community/showthread.php?t=128070)
dahugo 07-29-2015 04:09 PM
Gents,
My partners and I have just purchased an iPad Mini 3 and Stratus 2 to get our ADS-B in, but we have to start thinking about ADS-B out compliance over the next several years.
My head swims when I read aviation consumer magazine concerning the various methods and boxes which allow compliance.
We currently have a KT76 transponder, a Garmin 430W, and Dynon D180. I need some input from you guys on the cheapest and easiest method by which we can become ADS-B out compliant with what we have already.
And by easy, I mean the least amount of rewiring and panels mods, couples with a cost effective solution. So, anybody have any ideas for us?
PaigeHoffart 07-29-2015 04:19 PM
Replace the KT-76 with a KT-74 or Trig TT-31.
Paige
jclark 07-29-2015 04:28 PM
TT-31 should be rather easy
Originally Posted by dahugo (Post 1001604)
Gents,
Probably a Trig TT-31 being fed from the 430W.
Initially the Trig will slide into a King tray. There are one or two additional wires that will need to be added and you should be good to go.
James
p.s. I have a Trig TT-31 connected to a Garmin GTN 650 in an RV8 and a Trig TT-22 connected to a Garmin 400W in an RV6. Both Trigs need the latest firmware update. I have it installed for the TT-31 but am waiting to get it for the TT-22.
GalinHdz 07-29-2015 05:00 PM
Gents,
Paige
+1. IMHO this is the best way to go about it.
:cool:
BobTurner 07-29-2015 05:13 PM
+2 TT31 will read Garmin's ADSB+ output.
Note 1. You may need to upgrade your 430W software (you need version 5.03, I think, or higher) to get the needed ADSB+ output.
Note 2. Still waiting for Trig to make TT22 able to read ADSB+.
Walt 07-29-2015 06:50 PM
FYI: The Trig is a slide in replacement for the KT-76A, not the KT-76, so you will need to change the tray and re-wire.
