FAA Phone Call -- ADS-B Unit Non-Compliant
"FAA CENTRAL" just gave me a phone call ---- my SkyguardTWX transceiver is "non-compliant" and MUST be turned off ---- continued use would elicit a visit from the local FSDO.
Obviously, a lengthy discussion followed. The FAA (his) position is that none of the portable transceiver units meet the approval (for use) of the FAA and should not be sold or used. This individual is going down the list and giving over 400 of we non-compliant persons a friendly call. He also indicated that they continue to have problems with compliant, installed units, mostly due to installation and setup errors. So, when I fly, tomorrow, my unit will be turned off, and I will miss the traffic and weather reporting safety enhancements that I have really enjoyed! |
Quite honestly this should be no surprise.
Is there some way to turn off the transmitter only? Then you could at least receive weather, and some traffic. |
This has been reported to Don @ skyguard he has been aware of this issue.
They have their own forum on his website that he sells the unit from. Did the FAA rep give you specifics of the issue? here is a link to the issue, http://adsb.skyguardtwx.com/forum/sk...ations/page-2/ |
Asking about that
I have an email to Don, at Skyguard about turning off the transmitter --- but, we are in a busy traffic area --- really going to miss the extra set of eyes.
R. |
Welcome to VAF!
Joe, welcome to VAF:D
Thanks Mike!
I am following the ads-b stuff.... Waiting for my exp box to arrive from Navworx. Done alot of research on this stuff for a while. |
I just downloaded the app for the sky guard and if you see on the top right say transmit "on" its green in color.
Touch where it says "on" and then it will say "off" in red color. Hope this helps. |
Anyway there's been a lot of good discussion on this topic by people who know more than I do -- search for ADS-B on the entire forum, or see for example this thread and this one for much more good info. |
>> Quote:
He can operate with SIL=0 until the mandate, then will need a compliant GPS. True but as of Jan 2016, SkyGuardTWX and similar portables will not trigger a reply from a tower as it does today, the FAA has made that clear. |
:cool: |
| All times are GMT -6. The time now is 10:16 PM. |
