VAF Forums
-   Fuel Injection Systems (https://vansairforce.net/community/forumdisplay.php?f=94)
-   -   Fuel pressure high with boost pump on (https://vansairforce.net/community/showthread.php?t=126870)
vluvelin 06-20-2015 10:55 PM
Yesturday on final flipped on boost pump got alarm to check fuel.
Fuel pressure jumped to over 100 psi.
Airflow performance regulator stuck close.
O ring somehow got bigger. Replaced O ring with someething similar.
Now getting intermittent fluctuations up to 50 psi
Does anybody have part number ,size ,or place to purchase correct O ring????
On AFP wesite can not find any documents for FM-200 servo.
Can this high pressure do damage to servo?????
Maybe someone have some document like user manual and can share?..
Thank you
Taildrgr 06-21-2015 07:25 AM
Here is the text of an email I sent to Don at Airflow Performance. His contact info is at the end.
Email Quote---
When I turn on the boost pump, the pressure shoots up and over ranges the pressure sensor (>60 psi?) for a second, then drops to 25 psi.
The relief valve is sticking.
Did the temporary high pressure damage the fuel injector servo or mechanical fuel pump?
Don's response---------
This is normal for this pump as the relief valve poppet seats into an O-ring. This may be more prevalent depending on the type and brand of fuel that is used and if the pump has been sitting idle for some time. The poppet may stick a bit in the O-ring when the pump is first turned on. We have a different material O-ring for applications using alcohol which may not swell as much as the O-ring that is installed in the normal boost pump assemblies. I can send you a different O-ring if you provide me a mailing address. You will not damage the pump or the fuel control with pressures at 60 PSI.
Don Rivera
Airflow Performance
111 Airflow Drive
Spartanburg, SC 29306
Phone: 864-576-4512
Fax: 864-576-0201
E-Mail: don@airflowperformance.com
Web: www.airflowperformance.com
End quote--------------
DanH 06-21-2015 08:52 AM
Gentlemen, just to clarify, are you having this problem with the old style pump assembly....
...or the new style pump assembly?
Taildrgr 06-21-2015 08:57 AM
My pump is the old style.
vluvelin 06-21-2015 09:23 AM
Yes
Looks like picture 1 old stile
It was no problem with high pressure or sticking regulator before
Allways used 100LL
DanH 06-21-2015 10:55 AM
Old style...ok, that's useful info.
Be aware that the dual diaphragm operating scheme of an Airflow Performance or Bendix type fuel control makes them insensitive to inlet fuel pressure. Put another way, the pump pressure regulator can stick, but it's not likely to make any difference in the way the engine runs.
Not much worry about damage either. The normal fuel pressure operating range for an Airflow FM-200 is given as 20-90 psig. The Precision Silver Hawk (same basic operating principle) is 20~50 nominal, max operating 80, and a momentary pressure max of 140 psig.
vluvelin 06-21-2015 11:13 AM
Thank you Dan
Taildrgr 06-21-2015 11:22 AM
Thanks for the feedback, Dan.
Do not want to hijack the thread, but here is some additional info for those that may have a similar situation:
My pump had sat dry for 3 years before first engine start. The check valve stuck on the first use each time I used the pump and subsequent uses were ok within the same engine run period. After the pump sat for a few days, it would stick again on the first use.
However, on the second flight, it worked fine with no pressure spike on initial use. Have not flown since, but maybe the valve has loosened up by now.
Note that each time after the check valve becomes unstuck, the fuel pressure is steady at 26 psi with the pump on, 24 psi with the pump off.
airguy 01-04-2016 09:10 AM
Reviving this thread, I have had E-10 premium autofuel in my fuel system for about 2 months now and had clean forgotten about this potential O-ring issue. Last night I ran my engine to check a few things before my airworthiness inspection, and both pumps (old-style) briefly touched 60psig on initial run, which caught my attention. Apparently 2 months of exposure was enough to cause some swelling and sticking of the pressure relief valve, I have sent an email to Don Rivera for the replacement material O-rings.
Just a data point to consider.
vluvelin 01-04-2016 08:34 PM
Not in my case my fuel system don't see any other fuel then 100LL
You should check fuel pressure sensor that could be issue on its own
When my O ring got stuck I could hear fuel pump change its sound
