Videos to remove and reinstall impulse slick mag?
Its time for my one mag to be sent in for 500hr check over. I would like to remove it myself and learn but also dont wish to be foolish.
Is this something simple to do or is it wise to pay to have it done? A quick look on line to find at least a vid or tuturial so i can see what is involved and what i need to know would be great so i can decide if its a skill to learn or better left to pros. I will have the reinstall done and it set by a pro...just like to keep learning and taking it off and sending it off for inspection should be stuff i can handle no? Comments or tips welcome. |
Not a video, but a good book that is out of print, but copies are available:
http://www.amazon.com/Magneto-Igniti.../dp/B0006P6ZLW While it's probably not kosher from a copyright perspective, google is showing a link to pdf versions 17thjdc.com/pdft/sky-ranch-engineering-manual.pdf |
You will need a timing tool to reinstall and a new gasket as well, along with the maintenance manual for your engine.
Search the internet for magneto timing. Maxwell Magneto in FL is highly recommended. They did the Slick mags on my Cherokee last year. |
Slick Mags
It's easy to do; I've done it many times, and if I can do it, anyone can! The trick to reinstall is having the timing pin that goes in the little hole in the back. It can be a little tricky to tell when it's in correctly.
As Paul stated, it is not a difficult process, and with some over the shoulder advice on the first attempt you will have it down! |
Slick install
Always use the attachment hardware specified in the engine parts book including new lock washers.
Don B RV 9 rebuild in progress |
Rick,
Insert timing pin into hole marked "L" n mag rotate the gear till the pin slides down to the first shoulder Set. Tdc #1 cylinder compression stroke Turn prop for appropriate timing for your engine Insert mag, snug hold down nuts REMOVE PIN before turning anything. Adjust to final timing Install cap If you have trouble, call me and I will walk you through it We send our mags to Aero Atelier in lac a la Tortue in Quebec. The are a fine engine shop and quick to return repairs. Gary |
IMPORTANT
After step 5 (mag installed) REMOVE THE PIN from the mag prior to turning anything. |
Thanks Bob |
| All times are GMT -6. The time now is 11:33 AM. |
