RV-8 Fuel Flow Sensor Position
My -8 Fuel Injection pump is set up per Van's drawings. With this; the distance from the pump exit to the firewall bulkhead fitting is only a couple of inches. Can anyone tell me where they are positioning their fuel flow sensor?
I'll be using a Grand Rapids EFIS and flow sensor. Thanks I've seen many notes over the last months regarding straight runs in/out, but not the usual location - I expect some interesting discussion. :D |
RV-8A Fuel Install
The red square object is my fuel flow sensor (Blue Mountain)
[img=http://img294.imageshack.us/img294/88/fuel0004cm6.th.jpg] |
| All times are GMT -6. The time now is 04:38 AM. |
