VAF Forums
-   ADS-B (https://vansairforce.net/community/forumdisplay.php?f=113)
-   -   ADS-B Antenna Splitter for dual ADS-B IN? (https://vansairforce.net/community/showthread.php?t=126473)
Dan Langhout 06-08-2015 12:52 PM
Has anyone by any chance installed dual ADS-B IN receivers and used an antenna splitter to feed them? I am considering installing both a Dynon SV-ADSB-470 and a Garmin GDL-39R and would like to avoid installing two receiver antennas if possible. Any RF guys out there have an opinion?
And because inquiring minds want to know - I have both a Dynon Skyview and a Garmin GDU-375 in the panel which, for various reasons, I would like to receive ADS-B IN. Ah if only there were interface standards . . . . . .
dynonsupport 06-08-2015 01:32 PM
Dan,
A splitter should work fine. Just make sure you get a quality one that covers both 978MHz and 1090MHz.
The downside to using a splitter is the signal loss. You can't split a signal without giving half the power to each device, so you lose some range when you do this.
A $20 transponder antenna is going to cost a lot less than a good splitter.
--Ian Jordan
Dan Langhout 06-08-2015 01:37 PM
Drilling Holes
Originally Posted by dynonsupport (Post 989205)
Dan,
--Ian Jordan
Thanks for the response - good info.
The issue for me isn't the cost of the antenna or splitter, I just would like to avoid poking two more holes in the airframe and running two cables.
BobTurner 06-08-2015 01:54 PM
A lot of people have had good success with putting the little antennas that come with the unit inside the airplane (just not behind metal). I have them on my fiberglass doorposts (-10) and they work fine.
Yes, I think the Dynon will only work with the Dynon, Garmin only with the Garmin. Not universally true - GRT and WingX will work with a number of different ADSB-in boxes.
