Reserved "N" numbers available
A heads up. I have two "N" numbers reserved for the RV10 that I am going to let expire July 18, 2015; N910RV and N410JD.
Short-N-Numbers
I would like a short number but going to the FAA site, I cant give them a combo of starting range and trailing characters that works. Any ideas? Maybe my browser is not allowing it.
i'd love to change my registration but im apprehensive about the paperwork.
Which N-Number Are You Looking For?
Does this help you out? http://caura.homenet.org/nsearch/ If you need some help, gimme a shot. Regards, |
Other than the sheer number of N-numbers, what's to prevent someone from registering them ALL (could probably write a bit of software to manage the registrations, fees, and renewals when due), and then charge sky-high prices for them? Hmmmmm.... |
squatter
I'll bet that if the FAA took a closer look at this, they would not be too thrilled with it. |
| All times are GMT -6. The time now is 12:41 PM. |
