Old baffle kit vs new
I've been offered a baffle kit from 2003 which presumably is what I have seen referred to as the old baffle kit.
Would anybody who has used the older kit care to comment on whether the new is a bit less work, or a lot less work, or in a totally different league from the old? I'm not opposed to using the older kit but would welcome opinions. Thanks. |
Many people have built from the old baffle kit - no doubt about it (and I am one of them. I have also built or been part of building several of the new ones. Totally different league in terms of ease of building IMHO.
We needed a baffle kit for another (non-RV) project - we bought a kit from Van's because it fits the motor so well - we'll just trim it to fit the cowl (the same way you do for the RV's). Paul |
Thanks Paul, that's exactly the sort of info I needed.
Are you mounting the oil cooler on the baffles in the standard location? I believe the newer kits have a tougher aluminum alloy for this section that may help to reduce/prevent cracking.
OP - If/when you get that kit, let me know and I will send the metal thicknesses from the "new" kit for that cooler corner. |
When was the crossover from old to new version?
Thanks, Russ |
Thanks for the info folks.
I'm not yet decided on the oil cooler location, but have read plenty on the rear baffle cracks when no reinforcement is used, so that's a good point on the material thickness and type. If I do end up buying this kit I'll report back on that area. |
I've done both baffle kits and didn't find the older set that confusing. I had to modify the old set to fit on an O-290, which is different than an O-320 or -360.
The new baffle kit I installed went on an O-360 and since I had done the older kit, it was pretty straightforward. The new style kit has better instructions and CAD drawings rather than some copies of a copy of a copy of some old hand drawings. If you can read a drawing, which by the time to you get to this point you can, you won't have a problem with the older baffle kit. Quote:
1. Yes, on the angel on the vertical corner by the #4 cylinder. 2. Yes, on a brace from the right side of the oil cooler to a stiffener on the side baffle of the #4 cylinder. (Disregard the nyloc fastener, that was changed before the first engine run.) 3. NO on any brace that spans more than one cylinder or goes from a cylinder baffle to the engine case. The cylinders are not part of the case and move around a good bit so anything that ties one cylinder to another or from one cylinder to the engine case has a good chance of experiencing cracking issues. (Note, fiberglass plenums give enough that they do not experience this problem but I have seen aluminum plenums with cracks.) If you go with #1, which I like much better than the other options, you will have to file down the corner of the angle aluminum so it nestles in the corner of baffles. Not a big deal but something you will have to do. |
I've got 1800 hours on the Val's baffles, and my brace goes to a boss on the case Bill. The inboard side of the oil cooler is about half-way out the cylinder, so it is kind of a coin flip which way it should go - remember that the baffle just inboard of that point is tied to the case.
In any case, I believe that brace does a lot to enhance baffle life! |
| All times are GMT -6. The time now is 04:41 PM. |
