VAF Forums
-   -   Dynon EGT probe install (https://vansairforce.net/community/showthread.php?t=126102)
skyking902001 05-27-2015 01:44 PM
I drilled 1/8" holes in exhaust pipes per instructions. The probes don't fit thru the holes. I tried a #30 hole in some scrap--the probes fit nicely. I might be able to force the probe into an 1/8" hole, but doubt if I could ever remove it. Would #30 holes be acceptable? Anyone else have this issue? Thanks in advance.
Steve
jimgreen 05-27-2015 01:51 PM
I needed #30 holes too. I don't see any down side.
Jesse 05-27-2015 04:40 PM
A #30 hole is fine.
skyking902001 05-27-2015 08:10 PM
Thanks!
Thanks guys! I was thinking a #30 should be ok, but thought I'd better check with the group just to be on the safe side.
Steve
