VAF Forums
-   -   Newbie to VAF, looking to buy a standard kit (https://vansairforce.net/community/showthread.php?t=125752)
Gonefishing77 05-16-2015 05:21 AM
Hello people of VAF,
I am new to this site and looking into purchasing a Vans RV7 or RV14 standard build. Financially leaning towards the RV7, but am wondering if the RV14 would be a better fit for me (6'3" and 235lbs) and worth the extra money??. Also, Does anyone know when the finishing kit will be available on the RV14 and what is the likely price?? Trying to gather as much wisdom as possible before committing
I am living in Adelaide, Australia and am wondering if anyone else is local and has any tips/pointers about getting the process started or things they wished they had thought of prior to buying the first kit?
Many thanks,
Peter
bret 05-16-2015 06:59 AM
Welcome to VAF! As a data point, I am 230 and 5' 8" and fit well in the 7
kamikaze 05-16-2015 01:40 PM
"when the finishing kit will be available on the RV14 and what is the likely price??"
You can order it now, though not sure when they'll start deliveries.
12 650$US
wirejock 05-16-2015 04:55 PM
Welcome
Many thanks,
Peter
Welcome Peter
Tips
Watch the EAA videos. Read every thread in the VAF "Tips" section. Once you find a local mentor, build the two training kits then drill them apart and build them again. Why? Because drilling rivets is almost as important a skill as driving rivets.
Always do a search before starting an assembly. Someone has been there, done that and hopefully posted "gotchas". You'll make plenty of mistakes of your own. No sense making other people's mistakes. When you do make one, don't be shy. We never stop learning.
Finally, don't buy anything until you get your significant other involved.
Gonefishing77 05-17-2015 12:19 AM
Thanks guys... Do you know if the new kits come with the required parts to c/o required S/B's or do you have to buy these additional to the kit??
PIN 37 05-17-2015 12:35 AM
Gonefishing77
G'day, I am in Adelaide and am just in the process of painting and final assembly of an RV7. PM me and let me know where you are. :)
skylor 05-17-2015 12:54 AM
RV-7 Size
Many thanks,
Peter
Peter,
I am about your size at 6'3" an 240#. I fly an RV-8 which is extremely comfortable for me, but I took my transition training in an RV-7 and found it to comfortable as well.
Skylor,
RV-8, Flying 400+ hours
Gonefishing77 05-17-2015 12:58 AM
Thanks for the info Skylor...
Gonefishing77 05-17-2015 01:02 AM
12 650$US
$12650 for the finishing kit will make the standard kit more expensive than the Quickbuild??
kamikaze 05-17-2015 04:42 AM
The quick build is just the airframe ... you will need to buy the finishing kit regardless of whether you go standard or quick build.
SB Wing + Fuse = 7805 + 9795 = 17600
QB Wing + Fuse = 30250
And then there will be the empennage kit, finishing kit, firewall-forward/power plant kit and avionics kit.
