RV-7 or RV-14 for higher altitude XC
Hi folks -
I decided to throw this dilemma out to the community. I currently fly a Mooney 252, but my situation is changing. I would like to acquire or build a Vans. My mission: fly myself and wife on 300-600nm trips, some of which would be to CO or NM where the MEA might be as high as 14,500. I'd prefer to go higher - I've done many legs in the flight levels in my Mooney so oxygen is not an issue. The question - putting aside cabin size, cost, etc, to what degree will the -14 be a better higher-altitude aircraft than the -7? Specifically I'm talking high-elevation airport operations, ability to climb to 17,500 (or higher if possible), and stability up high and under IFR conditions. And also, comfort. Noise, cabin heat at altitude, and protection from sun glare on long trips would be the major criteria. On paper, the longer wing and slightly higher power of the -14 has got me leaning that way, but I'm not sure how big of a difference there actually is between the two airframes, for my missions. Thoughts? |
Considering that there is only one 14 flying---------I suggest you talk to the factory folks to get the straight scoop, based on empirical data.
Don't forget the -9!
-jon |
To mosquito's point, he did say that the -9 had the best wing for this type of mission, and would be the most efficient. |
If you're selling the Mooney, shoot me a PM. |
Suggest you add up your weights, typical baggage, etc., and compare to real world useful loads. Paint, plush interiors, insulation, it all adds up. My wife and I are a bit under 340 lbs total, but our dog is also 70 lbs, so a -7 with full fuel can't carry us, the dog, and camping gear.
The -14 definitely has more elbow room. |
And price aside, the -10 is probably the best high altitude performer combined with the insane amount of room and comfort. Don't let anybody sell you on the idea that the -14 is just a 2-seat -10. It's really just a bigger -7.
RE: RV7 or RV14 for Higher Altitude XC
rvbuilder2002 made an interesting post after flying the RV14a to the Copperstate Fly-In back in 2014. The post provides some useful comparisons between how the RV-7A and RV-14A perform.
I don't know how to provide a link to the specific post, but if you do a search for RV-14A operating experience you should find the post I am referring to. |
| All times are GMT -6. The time now is 12:40 PM. |
