VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   RS232 shielding question (https://vansairforce.net/community/showthread.php?t=124363)
YellowJacket RV9 04-02-2015 04:09 PM
I am working on interfacing my GRT Sport with my Garmin GTR-200 comm. The Garmin wiring harness included a shielded RS232 input wire, but it does not reach the EFIS. To test things, I spliced an unshielded wire to the center of the shielded wire from the radio, and ran that to the EFIS. The serial link works fine, but I am getting interference in the radio with the EFIS on.
The GTR-200 manual shows the RS232 serial line grounded at both ends with the shield. First, would it be acceptable to splice a new shielded wire to the end of the first? And second, where should I ground it at the EFIS side, as there is no grounded metal backshell?
Thanks for any input!
Chris
Jesse 04-02-2015 05:54 PM
Generally shielded wires are only geounded on one end. Splicing shouldn't be a problem.
rbibb 04-03-2015 03:56 AM
That depends. General rule is:
If you want to keep EMI inside the cable, ground both ends. If you want to keep the EMI outside the cable, ground one end.
So if a signal is small in magnitude (think audio signal like microphone circuit) ground one end to keep interference from outside corrupting the signal inside the cable (including interference created by a ground loop if you were to ground both ends).
If you are connecting something like a strobe signal (large AC signal) go ahead a ground both ends as goal is to make sure what is inside doesn't radiate to the outside (groundloop induced corruption of the large strobe signal is a non-issue).
In the case of an RS-232 signal you have a fairly large signal [5V or more Peak to peak) running at almost 10KHZ baseband frequency (or more)]. Radiated harmonics could cause all sort of issues. Hence, ground both ends. Use a connector with a metal hood and round the shield to whatever pin the EFIS designates. As usual, AeroElectric Connection shows good techniques for doing so.
YellowJacket RV9 04-03-2015 06:28 AM
Thanks guys for the input. A little more investigating this AM may have changed the culprit. It now appears my Dynon D10 is the source; not the GRT systems as I had thought. This was just the first time I had had my headset plugged in and noticed the interference, and it is only on some of the lower frequencies (<124 Mhz). I can definitively start and stop the interference by powering it on and off.
I will talk with Dynon, I hear they have an EMI filter dongle for their d-sub connectors that may help.
Chris
Jesse 04-03-2015 06:38 AM
I was going to mention that, but it sounded from the OP that the static came when you added that wire. I have a lot of serial wires unshielded with no problems. That doesn't help solve your problem, though
YellowJacket RV9 04-03-2015 07:26 AM
Yea I found it odd that I had three other serial lines unshielded with no issue. Apparently I plugged my headset in for a different reason at the same time I connected that serial line. Goes to show the imprtance of methodical troubleshooting.
Apprently the EMI is a known D10 issue.
Chris
lrgabriel 04-11-2015 12:36 PM
Originally Posted by rbibb (Post 972429)
General rule is:
This isn't really the case.
Terminating the shield at one point vs. multiple depends on the electromagnetic coupling mode you're trying to defend against (electric or magnetic)[1]. Electric coupling is a function of the capacitance across the insulator between the signal wire and the shield[2], while magnetic coupling is picked up by the loop formed by the cable and the ground plane[1].
Low frequency signals interfere via magnetic coupling, and high frequency signals via electric[1][2]. Therefore, when trying to defend against low frequency interference (like when you're trying to protect a low frequency audio signal), you use single point shield termination to avoid creating a loop/current path for magnetic coupling to occur. For high frequencies, it's important to reduce the voltage accumulating on the shield, so multiple grounding points are used[2].
[1] Fr?bel, Anke. "Cable Shielding to Minimize Electromagnetic Interference." Cotbus University of Technology, Germany.
[2] Renner, E. NAVSO P-3181 Aircraft and Avionics Cabling E3 Design Manufacturing Guidelines. U.S. Navy, 1992 para 4.3
ricardoramos 07-07-2015 08:52 AM
I know it may sound dumb, but I need some clarification on shielding on data cables.
As a broadcast engineer, I am used to ground cable shields at one end only. This is a very standard practice in balanced audio cabling.
I came to a halt when wiring RS232s on my 10. I have dual G3Xs and a VPX-Pro. I need to connect the MFD to the VPX using the RS232 and I wonder if should I use a 3-conductor shielded cable (TX, RX and SIGNAL GND) and have them all connected respectively with the shielding grounded on the backshells OR should I use a 3-conductor shielded cable and have the cable shielding acting as SIGNAL GND connector ???
Clarifications will be much appreciated.
Ricardo
Brazil
SMO 07-07-2015 09:20 AM
Page 21-9 of the G3X installation manual shows the RS232 connection to VP with a 3 wire shielded cable, one of the 3 wires goes to a signal ground pin on each end, and the cable shield is separately grounded externally on each end.
ricardoramos 07-07-2015 09:36 AM
Thanks for the reply, Mark. I totally overlooked that. Makes sense now.
