VAF Forums
-   -   Cummins metal spinner (https://vansairforce.net/community/showthread.php?t=124090)
Charles in SC 03-24-2015 03:15 PM
Has anyone here had any experience with these? Good or bad.
AX-O 03-24-2015 03:23 PM
If you are talking specifically for the Catto props; no. They are not done yet. I have been working with Allen to get this done. I should be receiving the spinners in a few weeks from Australia for trial fit.
If you are asking for other prop types, they are out there and I have not heard anything negative.
Taildrgr 03-24-2015 03:31 PM
I have one with a Hartzell CS prop and it was easy to install and fits perfectly. I polished it myself and it came out looking great. I am very pleased with the spinner.
Larco 03-24-2015 05:51 PM
C/S Hartzell. Fine workmanship and good guy to deal with. Couldn?t be happier. Larry
Ironflight 03-24-2015 06:23 PM
We were sent one to evaluate by Cummins.
Took me less than two hours to install on the RV-6, fit perfectly, and is beautifully constructed - this is for the C/S Hartzell. Really a great product if you are looking for an alternative to the standard RV spinner - and the holes for the blades are already cut.
Paul
KRviator 03-24-2015 07:54 PM
I have one for the Sensenich G/A prop - the prototype actually - and other than having to trim a mm or two off the aft end due to a tighter-than-stock cowling clearance am entirely happy with it. It's polished up very nicely! The only thing I'd suggest as an improvement is a pair of blanking plates for behind the blade to better seal that area. Takes all of an hour to make them yourself though, so it isn't a big, or even a minor, issue really.
Here's a photo I took yesterday on the way to the songwriters. Doesn't show all the spinner, but close enough!
Here's what is in the box.
Charles in SC 03-24-2015 08:42 PM
Thanks, I think I am going to pull the trigger on one.
southtarnation 05-10-2015 07:26 PM
I dont see the 13" spinner for the Sensi Ga prop on his website. Any idea of when they will be available or for how much?
Did you weigh it?
rvator51 05-10-2015 07:44 PM
The spinner for the Sensenich metal fixed pitch prop for an O-360 is available. We bought one about two months ago.
Dundee Downunder 05-11-2015 06:47 AM
Chromed
Very happy with mine ... followed Alan's instructions by getting it
professionally polished and then, for a small amount extra, getting it
chromed.
Cheers, Rob
