Fuel/Air Stoichiometry vs Peak EGT?
I'm not 100% sure this belongs here but is a fuel related question...
Is anyone aware of a general chart or formula showing EGT vs actual stoichiometric air to fuel ratio in internal combustion engines? I am attempting some calculations about theoretical fuel burn and keep coming up with less fuel flow than expected for a given MAP. My assumptions are that at a given MAP, the combustion chamber fills with ambient air and that the fuel metering device, be it a carburetor or fuel injection system, is in turn metering Fuel in based on the air flow. It seems that if I use the MAP as the basis for calculating the molar composition of the precombustion mixture, I get lower fuel flows than expected at a given engine speed. I know that I could calculate this by playing around with adiabatic flame temperatures in the combustion chamber but quite frankly I am not trying to write an undergraduate engineering thesis, just understand the relationship of fuel:air mixture to EGT a little better. Anyone know when we talk about peak EGT, just how close that is to the actual stoichiometric air requirement? |
Remember from the 100% of the BTU?s that the fuel makes, you are only going to get about 30% of that energy that actually makes HP. From studies done at Lycoming .065 is around peak EGT. I believe .062 is stoichiometric.
Don |
Now what I'm trying to do is figure out what stoichiometric ratio is implied by a "full rich" mixture setting. Obviously for a normally aspirated engine this will change based on altitude. Again thanks for the response! What are the units on your numbers above or are they just fuel:air versus air:fuel (i.e. 1/the ratio I am using)? 1/12.5 = 0.08 |
![]() C.F. Taylor, from previous studies, peak about 0.066 ![]() The recent (relatively speaking) Swift fuel study done at the FAA's Hughes Technical Center is one of the few windows for folks like us, given that manufacturers like to label everything Top Secret. It lists the calculated stoichiometric ratio for 100LL at 1/14.9, or 0.067. The graphs for baseline runs at various power settings (IO-540K) have peak EGT right around 1/15.2 (0.066). Download here: http://www.tc.faa.gov/its/worldpac/techrpt/ar0853.pdf As a practical matter, I just consider peak EGT to be stoich and carry on. |
Ah, excellent, thank you! So with 15.2 being the empirical stoich for 100LL6, the average molecular weight (carbons in the chain) must be higher than straight octane, which makes sense since there are bound to be some other constituents in the blend. Anyone have a chemical analysis of 100LL? Taking into account that there are probably some esters and alcohols in there contributing oxygens of their own, the amount of carbon is probably even a bit higher. |
I also now see that my ratio of 0.08:1 could be seen as the "best power" mixture as it represents the most fuel it is possible to burn under normally aspirated conditions. However, I would imagine there are not insignificant effects associated with the nitrogen content of the combustion air and other things like water vapor.
With straight Mogas (no ethanol) we figure 14.7 AFR is stoich and peak EGT which is .068 in the units on the charts.
Yes, my calcs right now are a first approximation to validate my method. I will tighten things up later to include this sort of concern. I have a factor in there but it is just set at one right now. Things like the effects of valve overlap and incomplete exhaustion are in the future. |
| All times are GMT -6. The time now is 04:35 AM. |
