VAF Forums
-   -   Ipad weight and balance calculator (https://vansairforce.net/community/showthread.php?t=123736)
JCSmith 03-13-2015 08:49 PM
Would like to ask if anyone is using an iPad app for weight and balance calculations for an RV-6A? If so which one(s) works best.
ChiefPilot 03-13-2015 09:06 PM
I just made a simple spreadsheet in Numbers that computes all the relevant data plus max load factor along with stall and corner speeds for the resultant weight.
BruceEicher 03-14-2015 12:32 AM
WnB Pro. Quick and easy.
Malndi 03-14-2015 02:11 AM
Avplan
I use Avplan which has a nice WnB feature built in.
JCSmith 03-14-2015 07:29 PM
I'll take a look at those, thanks!
GalinHdz 03-14-2015 08:25 PM
FltPlanGo has the RV6A, RV7 and RV10 W&B in it's database. And the app is free.
:cool:
Henryrifle 03-14-2015 09:46 PM
Foreflight Pro includes weight and balance. If you have your actual data, it is easy to set up and seems very accurate. Easy to use too.
David Paule 03-15-2015 08:57 AM
Flightscale
Seems to have the features and it's what I've been using.
Dave
JCSmith 03-16-2015 09:13 PM
Thanks for the responses, these sound good!
TCONROY 03-28-2015 10:49 PM
I tried setting up ForeFlight W&B for my -7 but keep getting an error stating the aft cg limit needs to be behind the forward limit (which it is). I can't get past that error. Care to share the data you entered?
