VAF Forums
-   -   How to remove flap anti chafe tape ? (https://vansairforce.net/community/showthread.php?t=122933)
Larry DeCamp 02-18-2015 07:35 PM
My rehab project has a clear tape on the curve leading edge of the flaps. It is very thin and won't peel off. Any suggestions for removal??
David Paule 02-18-2015 08:09 PM
Perhaps a heat gun will loosen the adhesive.
Dave
AlexPeterson 02-18-2015 08:48 PM
Oh my, your problem brings back memories... I do not have good news - it was awful getting that stuff off mine after around 6 years. I made scrapers from plexiglas, and used a heat gun. There were many, many hours involved. The plexi scrapers worked reasonably well, but they were fairly narrow IIRC. Too wide and one can't get the pressure needed. I tried various solvents, but since mine is painted under the tape, I didn't want to get too aggressive.
For those not following why this is a problem - the polymer crazes and cannot be pulled off. Small shards come off instead.
Patience....
Kyle Boatright 02-18-2015 09:01 PM
http://www.vansairforce.com/communit...t=uhmw+removal
rjbob 02-19-2015 12:13 AM
Originally Posted by Kyle Boatright (Post 960593)
Thanks for the GREAT link, Kyle!
An added plus in the thread is info on a product that is a viable alternative to the tape most of us use.
DanH 02-19-2015 05:17 AM
In the truck business we peel a lot of vinyl lettering. On a commercial level, the typical aluminum truck box is stripped by placing a space heater inside, and heating until the outside of the box is about 200F.
If the material is too old to peel, attack it (gently) with a sharpened plastic ice scraper or similar.
Removing the leftover adhesive is painless with the right stuff. Go online and order a bottle of Rapid Tac "Rapid Remover".
strahler13 02-19-2015 05:59 AM
And when you are done, replace with stainless steel tape. Looks great and you won't have the same problem down the road.
gtmule 02-19-2015 07:26 AM
I was hoping Kyle would post this so I didn't have to find it. I used his method and can report that:
A) It works great
B) You need a plug-in drill motor, or you'll spend more time charging batteries than removing tape
My flaps are white so I bought some cheap white vynl vehicle wrap, 12" X 60" from amazon and cut strips to use as flap tape. Working great so far, and looks great as well.
Capfo 02-19-2015 07:28 AM
I replaced mine last month and the eraser wheel is the ticket! Took me all of about two hours.
