VAF Forums
-   -   Band Saw blade recommendation (https://vansairforce.net/community/showthread.php?t=122687)
Iluke 02-12-2015 07:09 AM
Hi everyone. Just (finally) bought a band saw and I'm looking for recommendations on a blade that would work better cutting aluminum that the one it came with which works but is a bit course (don't know the actual tooth count) and leaves a jagged edge.
My saw takes a 72 inch blade of between 1/8 and 1/2 inch width. On slow speed it runs 16 feet/min.
Any suggestions?
thanks,
Ivan
LifeofReiley 02-12-2015 07:27 AM
Ivan, I've used this blade for aluminum for 23 years, love it! :)http://www.sears.com/craftsman-1-4-x...p-00902625000P
N941WR 02-12-2015 07:54 AM
Since you are asking about blade size, I would go with an 18 TPI in the 1/4" size. Buy a couple of them and get a few in 1/2" just incase you need to do some long straight cuts.
To clean up the cut marks, I have one of these Delta bench sanders with 80 grit on the disk and 120 grit on the belt. After dressing my cuts on this, I finish them on the deburring wheel spun by my drill press set to the lowest speed.
wirejock 02-12-2015 08:08 AM
Blades
I use two. 14TPI for most cutting. 7TPI for angle and bar stock. Cut outside the line and sand using a disk/belt sander. The thick stock will dull a fine blade. Take your time and watch the kerf. The cut can wander pretty quick if you feed too fast. If it happens, back up a tiny bit and feed again.
Iluke 02-12-2015 10:49 AM
thanks.. 7TPI for thicker stock surprises me. I guess I was thinking the finer the better. Good to know.
And how about blade width. They sell them as small as 1/8 inch and those are advertised as being better for cutting curves-- A smaller minimum radius that the 3/8 that came with the saw. But I'd guess that the trade-off of a narrower blade would be it being harder to cut a straight line with it? Does that make sense?
380mxc 02-12-2015 10:58 AM
rule of thumb
The basic rule of thumb for band saw blade pitch is three teeth in contact with the material.
wirejock 02-12-2015 12:09 PM
TPI
YMMV. I'm breaking the 3TPI rule. It just seems like the 14 cuts so slow through thick stock, it gets hot and dulls fast. New blades too. The 7 cuts quicker and does leave deeper scars but cutting outside the line then sanding up to the line removes them.
You won't cut many curves but 1/4 is about right for most of what we do.
N941WR 02-12-2015 12:50 PM
Yes, but we really don't cut through thick stock. The thickest AA in the kit is still pretty thin.
I corrected my post above, I used 1/4" 18 TBI blades and they worked great on the sheet aluminum and OK on all the AA.
ninerhawk 02-12-2015 12:53 PM
Band saw blades
I ended up buying a custom blade for my Craftsman bandsaw and had great success cutting all kinds of aluminum. For exmaple, bandsawbladesdirect dot com allows you to spec out what you want at a competive cost, and at the blade length you specify. Blade speed is an important factor. Without speed adjustment, I wanted something with a higher tooth count.
