Screw holding question
What are some good ways to make a Phillips screw stick to the end of a screw driver so you can thread it in to a hard to reach spot?
Magnetize the screwdriver...
A dab of heavy grease... Masking tape... Or get a screw starter. Google it. Very few seem to have ever heard of such a thing, but it was something every IBM, Jensen and Techni-Tool computer field service engineer's tool kit had - back when big blue dinosaurs roamed the Earth. |
+1 for the screw-starter tool. They're available at the big box stores, or online: http://www.toolsource.com/phillips-s...p-p-71158.html
Solder
Add solder to the many tools or methods to start a screw in a hard to reach spot. Wrap it around the screw, get it started and then pull out the solder. Its soft enough to unravel without breaking off. Assembled many a radar set this way.
Screw starters on line
Had the same issue ---- got mine through Amazon --- be sure to get ones for both straight slot and Phillips head!
Fuel lube works very well in place of heavy grease. Plus it also makes a decent lubricant for the threads.
Screwdriver
Short piece of plastic tubing. Tubing has to be a snug fit on the screw head and the tip of the screwdriver. From recent Sport Aviation.
Working on electronics back in my early Navy days, we kept a wax ring that you would use to install a toilet... Quick jab in the wax and the screw would stick to the end.
Cheap and effective. |
Super glue. When the screw gets started, move sideways to break the bond. I've super glued lots of washers on nuts too.
| All times are GMT -6. The time now is 11:17 PM. |
