VAF Forums
-   RV-6/6A (https://vansairforce.net/community/forumdisplay.php?f=8)
-   -   Flap rod end security (https://vansairforce.net/community/showthread.php?t=122143)
Malndi 01-29-2015 03:46 AM
Going over my recently purchased RV6A with an AP (Aus equivalent of a DAR) we were both mildly concerned about the lower rod end bearing on the flap linkage. While the upper rod end bearing is nicely secured the lower end uses a bearing with an integral 1/4" stud, ie no place for a safety washer.
After consulting the preview plans I found that a CM-4S bearing with integral stud is indeed the correct fitment at this location. But it just doesn't look adequate for such a high stress component.
Is there another way of securing the lower end of the flap linkage, or am I unduly concerned? Appreciate your thoughts.
Mal
[IMG][/IMG]
Andy Hill 01-29-2015 04:10 AM
It is correct as per Vans, and it also contradicts "best practice" - as you've found.
I am not sure anyone has found a better / more correct way of doing it? Nor if anyone has suffered a failure?
It can also take a "home made" spanner to tighten the nut inside the flap (likely depends on type and how it is finished).
All I would suggest is ensure you leave the flaps partially down at shut down, and check the security of that fitting on every walkround.
TX7A 01-29-2015 07:21 AM
Thread locker
IIRC instructions also call for red thread locker during install.
petersb 01-29-2015 09:30 AM
Mal
[IMG][/IMG]
Simple fix, use a drill bit to remove the stud, and replace with a bolt and large washer.
Standard proceedure in Canada
Peter
Champ 01-29-2015 11:18 AM
I replaced the CM-4MS rod end with a CM-4M rod end, an AN4-15A bolt, spacer washers and 5/8" OD safety washer. The spacer washers & bolt length gave a much better alignment of the flap pushrod thru the fuselage opening. Also replaced the aluminum pushrod tube with 4130. Overkill - maybe? Peace of mind - yes. Picked this up on VAF - what a resource!
[IMG][/IMG]
rvbuilder2002 01-29-2015 12:43 PM
Another way to look at it......
This is the most easily inspected control system connection (rod end) on the entire airplane.
With the flaps extended (the way most in the know owners leave them positioned on the ground, so that someone doesn't unknowingly step on them when climbing in) it is right in plain sight and should be part of any pre-flight inspection (everybody does those right?).
The likelyhood of a failure occurring on that rod end during a flight (at least a failure that would be prevented by having a safety washer installed), without there having been some evidence of an impending failure that could be caught during a preflight inspection, is just about zero.
BTW, the photo in the previous post concerns me a bit.
The amount of washers visible makes it look like (could be wrong) that the stud length is quite a bit linger than if the specified rod end with integral stud is used. This would be causing the bending load on that stud (bolt) to be much higher than it is with the specified part.
JonJay 01-29-2015 01:08 PM
110% Scott..... I don't just look, I put my hand on these and give them a wiggle every flight.
2500 plus 6's flying, largest in the fleet, and I have never heard of a failure of the bearing.....
ao.frog 01-29-2015 02:02 PM
Preflight
Same here: I check those on every preflight since they are so easy accessible, and that's good enough for me.
No problems so far on none of my -7's (315 hrs / 60 hrs)
Malndi 01-29-2015 05:11 PM
Thank you all for your advice. I am persuaded to leave things alone, particularly by Scott's explanation of the unlikelihood of inflight failure. I already park with flaps down and this item is on my pre-flight checklist, but I now have a better understanding of what I'm checking. Thanks again.
Mal
Neal@F14 01-29-2015 09:42 PM
Stock Vans stud-type bearings with Loctite Red for the nut has been working perfectly fine on my RV-6 since it was built in 2003. No worries there. All the load on it is in shear anyway, and very little vibration to affect it. The extruded hex aluminum flap pushrods from Avery were treated with Loctite Blue in case they ever need adjusted or removed.
