Pictures of do-it-yourself interiors?
A lot of the interiors that are professionally done look really nice, but my budget will not allow them. I'm planning on mostly a painted interior but will likely put a few pieces of fabric here or there. I'm wondering if anyone who has done their own interior (side panels/arm rests especially) can post pictures showing what's possible. It would really help me know whether what I want is doable (by me). Thanks for any ideas.
Example from another homebuilt
Here's a description of how another builder did it on a Midget Mustang:
http://home.centurytel.net/midgetmus...s/sidewall.jpg Hope this helps, Martin |
My sew-it-yourself interior
There are a few pictures of the interior I sewed for my 6A at this website...
http://www.eaa582.org/gallery/thumbn...lbum=19&page=1 I bought the foam from Van's and the fabric from a local auto upholstery supply store. They let me take the fabric sample books home so my wife could help with the color & texture decisions. The fabric cost ~$200 and at the time Van's foam was also about $200. I also sewed seat heater elements ($70 for both seats) between the blue fabric and a 1/2" foam filler-layer that went over Van's foam. I love my heated seats the most after preflighting in single digit temps, while I wait for the engine to warm up! The side panels are made of corrugated plastic sign-board with a single layer of thin batting material and the color fabric wrapped around and glued on with 3M #77 spray adhesive. Real quick and simple. Most are just friction fit into the plane, 1 or 2 have a small piece of Velcro on the back. The armrests took a little trial & error. After the seats were done I sat in the cockpit making airplane noises. I decided I wanted to be able to rest my elbow on the armrest without leaning over, that required a layer of 2" (firm) foam. I mounted the foam to a piece of 3/8 plywood so I could staple the fabric cover on, and I mounted the armrest pad to the airplane with short wood screws, the ONLY wood screws in my all-metal airplane! The wood also adds a bunch of much-needed stiffness to the armrest. It took me about 6 weeks to make everything (nights & weekends). If you have more time than money (like me) then I think it's worth it. I never did any kind of upholstery before I started on this, but then again, I never built an airplane either! It was a great learning experience, the next time will be much easier. I don't know how much complete interiors are going for, but I have less than $500 + labor in my very custom interior. It also gave me an opportunity to teach my (then) 9 year old daughter how to use the sewing machine. This and the pride in knowing I did it myself = Priceless! I say go for it! |
An alternative to the high dollar interiors
I did my interior using materials from Flightline Interiors, Abby (the owner) is very nice to work with and does a great job, and they are very reasonably priced in comparison to some of the others.
Here are the panels I made for my interior. I used corrugated backer board from a local fabric shop and some 1/4" foam covered with leather. The units are then glued to the side of the interior with adhesive. I've popped them off once to work underneath them. I just pry off the glob of adhesive and re-glue them back in place. I thought they turned out okay. I'm about to remove them again so I can have them embroidered with the new theme for my airplane, once I get it back from the paint shop. |
Both great looking interiors. Randy, I really like your switch guards. Where did you get them?
Switch guards courtesy of http://www.periheliondesign.com/
Thanks Steve. Actually, it is quite easy to do. I don't have any special skills. I cut the backerboard to fit the areas I wanted to cover. I then cut the 1/4" foam to match, sprayed on some 3M sprayable adhesive, and stuck the foam to the board. I cut the leather slightly larger than the panel and cut little "V"s at the corners. I sprayed the back of the leather with adhesive and gave it a moment to set up. I then position the backerboard/foam over the back of the leather and set it in place. I pulled the edges around the corner and stuck them to the back. That's it. Anyone can do it. I used some general adhesive from Home Depot to stick the backerboard to the aluminum. None have come off in over a year and I can pop them off if I have to.
WOW! Awesome interior!
OK Randy, your interior must get ooohs and ahhhs wherever you go, and you must get a lot of this-
How about the wood trim? Real wood or...? Did you put the finish on or buy it that way? Any special installation for that? Approx how much weight? Looks like it carries on along the bottom of the instrument panel, or did it switch to leather? |
| All times are GMT -6. The time now is 04:05 AM. |
