VAF Forums
-   Glass Cockpit (https://vansairforce.net/community/forumdisplay.php?f=35)
-   -   Garmin G3X Touch Feature Wish List (https://vansairforce.net/community/showthread.php?t=121861)
Spirko 12-24-2015 11:59 AM
Originally Posted by GlennM (Post 1039767)
Requested Feature,
I have a G3x touch and a Rotax 912 IS Sport. The G3x uses the Can-bus to grab and display data like temps/fuel flow etc. BUT it does not allow me to access all of the data I want, specifically the Can-bus based Inlet air temp. This should be easy to add in as the code already accesses the can-bus ??
So my request is for the software to access all of the Can based data
GlennM
I have the same engine, it would be great if the G3X Touch could also read engine faults instead of my having to wire up the diagnostic software on a computer after I land.
maus92 12-29-2015 08:48 AM
I'd like the ability to display GDL-39R FIS-B info on either display (in a dual display setup.) Currently, it's only available to the GDU that the serial line is physically connected to.
g3xpert 12-29-2015 08:52 AM
Hello maus92,
Although it is true that the GDL 39 supports only a single wired RS-232 connection, you may optionally display FIS-B weather information on a second GDU 4xx display using the Bluetooth interface. This is documented in section 8.11 of the G3X Touch pilot's guide: http://static.garmin.com/pumac/190-01754-00_E.pdf
- Matt
Brantel 12-29-2015 01:39 PM
Yes, and it works very well indeed!
bkthomps 01-23-2016 04:15 PM
Looks like 4.10 is now out, can we get a mailing list or some sort of official notification going Garmin? Maybe they already have it and i'm the odd man out
Changes made from version 4.00 to 4.10:
Add support for UMA N1EU70D 0-70 PSI differential fuel pressure sensor
Add support for configuring Vne in terms of true airspeed using a different value from indicated Vne
Add support for high-resolution SXM TFR data
Add support for ETE To Destination and ETA At Destination fields in data bar
Add menu option to transponder page to test Mode S ALT reporting when on the ground
Add option to configure external light flash priority
Improve Connext Bluetooth interface
Improve weather data processing
Improve contrast when editing numeric values for PFD bugs and baro setting
Improve configuration pages
Improve gauge display for turbine engine torque and RPM
Improve display of highlighted traffic targets
Improve GPS data sharing between displays
General improvements to system operation
Includes update to GSU25 software version 3.50
Includes GAD27 software version 2.00
Includes GAD29 software version 2.20
Includes GDL39 software version 4.60
Includes GEA24 software version 2.60
Includes GI260 software version 2.70
Includes GPS20A software version 2.10
Includes GSA28 software version 3.00
Includes GSU73 software version 3.40
Includes GTR20/200 software version 2.70
siclick33 02-07-2016 05:23 AM
I might be a little paranoid about flap position sensor failure but.......
Unless I'm mistaken it looks like you can't set a 'max run time' for the flaps in the way that you can with the trim. This would be useful to protect against some form of position sensor failure if you're not using the optional end point microswitches.
Maybe it could also have functionality to quickly disable the flap position sensor operation completely, via the touch screen, so that you can still 'manually' raise and lower the flaps if the flap position sensor does fail?
It might also be useful if the system could provide backup control via the touch screen to allow trims to be returned to centre and flaps raised/lowered (as long as this doesn't introduce worse failure mechanisms) as an emergency redundant backup.
bkthomps 02-07-2016 09:22 PM
Setup the new ETAD (estimated time arrival at destination)
It consistently displayed the central time ETAD when my destination was in eastern time zone- is that the intent of the setting?
g3xpert 02-08-2016 08:07 AM
Hello siclick33,
The GAD 27 does not have a user-configurable maximum run time for the flap motor, but if the flap position sensor gets "stuck", it is smart enough to not run the motor forever. There are various ways one could imagine a flap position sensor misbehaving, but the GAD 27 is designed such that none of them will ever prevent the pilot from raising or lowering the flaps if he really wants to.
- Matt
g3xpert 02-08-2016 08:11 AM
Hello Brian,
The ability to display a field showing estimated time of arrival at the destination waypoint in the data bar simply repeats the same ETA information that was always available on the flight plan page. These values are always displayed using the currently selected system time zone.
- Matt
bkthomps 02-08-2016 10:52 AM
Originally Posted by g3xpert (Post 1052153)
Hello Brian,
- Matt
Feature Request - ETAD displays time at destination timezone :)
there was a Super Bowl party planning incident that involved relying on that ETAD field to determine when guests should arrive, it said ETAD: 16:11 which of course ended up being 17:11 EST
She was happy she did the military time conversion, not so forgiving when I explained the fancy avionics don't factor in time zones
4.10 does seem more stable, I intentionally tried to reproduce my bluetooth-induced software reboots and was not able to, thanks for all the hard work you guys do
Thermos 02-11-2016 07:13 AM
Originally Posted by g3xpert (Post 954294)
The short answer is no, G3X does not push it's internal flight plan to the GTN. You can enter flight plans directly on the GTN or using Garmin Pilot and importing via Connext.
Brian,
Apologies for possibly repeating a question, but pushing an IFR flight plan to the GTN from Garmin Pilot requires *only* the G3X Touch's Connext capability...no Flightstream required?
Dave
jthocker 02-11-2016 08:19 AM
Airspace upper/lower floors on G3X
I love the new "always on" floor limits for airspace's on Garmin Pilot app.
Will that soon be coming to the G3X displays????
bkthomps 02-16-2016 05:07 PM
Originally Posted by Thermos (Post 1053077)
Brian,
Dave
I have no flightstream and only GTN and G3x touch and it worked for me via Connext
maus92 03-03-2016 01:38 PM
G3X Touch: In split screen mode, I'd like to have any page available on both sides of the display. Currently, one side is limited to only a few page choices (I think Map, Chart, PFD?,) which is selected in the setup menu. I'd like the flexibility to use the knobs on both sides of the screen to scroll through all pages on both sides of the display.
freefly42 05-24-2016 08:19 AM
GTN Integration
Took my first long cross country over the weekend with the radio controls on my GTN 650 enabled on the G3X touch--LOVE IT!!
Just two things I regularly wish it did now that it doesn't. The fact that there's no way to send a flight plan from the G3X to the GTN is really odd--that I can send it from Foreflight on my iPad through the G3X to the GTN is amazing, but I should be able to do the same from the G3X.
Got an interesting modification to my IFR route the other day (complete change with V airways etc.) and loaded the direct-to for the first VOR in the GTN, and started off, but didn't want to mess with editing the flight plan on it for the very complicated route I'd been given. Had no choice but to plan it in Foreflight and send it over. Worked well, but with the panel I have I'd prefer not to be dependent on something not built-in for an important function like that.
Second thing is I can't display the time to VNAV as one of the data displays on the top of the screen. Am I just missing something? I'm constantly having to menu up on the main screen to check it. I can let the autopilot automatically pick it up, but when I'm IFR I can't, but I like to use it as a reference for when I should be reminding ATC to clear me lower.
Thanks!
NovaBandit 05-24-2016 08:40 AM
This is my favorite new thing as well! Love the ease of freq lookups on the G3X!
I've found that you can... kinda. You can build a flight plan on the G3XT and then send it to the GTN, just like you can with the iPad. (Going from memory now) I think you just hit the menu button from the flight plan page, and send to GTN should be an option.
However, I don't think you can do this when you're in flight and you're running the AP off the GTN's flight plan. Think about it this way. When you tell the G3X that it should follow the directions of the GTN, it's just displaying a read only version of what the GTN has loaded for the flight plan. And the autopilot in the G3X is going to fly that. To edit a flight plan, you need to switch the flight plan source to internal, which I believe will also switch the AP source to internal. Now you're flying whatever you had set up as a flight plan in the G3X before.
It would be nice if you could edit a GTN flight plan "on the fly" from the G3X (while it's on the external source), but my gut feeling is that this will be tough to do.
Thanks!
This has been possible since v4.0. It should be there if your software version is up to date. This is one of my favorite data fields.
Rick_A 05-24-2016 08:56 AM
Baro Data Field from ADSB
I have a data field on my Aera 795 that shows the ADSB baro setting. I wish this field was available as a data field on the G3X.
dweyant 05-24-2016 09:30 AM
I love my G3X with GTN650 setup. It is a great, rock solid IFR platform.
One feature I would really like to see is some sort of oil timer. Not a big deal, but it would be really nice to have a timer that tells me how many hours I have on my oil change.
-Dan
Jimd 05-24-2016 09:35 AM
Oil
I second the oil timer. I sent the Garmin guys an email asking about it because I thought it might be one more thing I missed in the documentation. Doesn't seem like it should be too hard to implement since the engine time is already there?
Jim
g3xpert 05-24-2016 09:47 AM
Hello Rick,
The Data Fields tab on the INFO page allows you to view all of the weather datalink fields including baro setting, winds, temperature, and dewpoint (provided by the nearest METAR).
Steve
stamper 05-24-2016 11:27 AM
To the G3X experts
I haven't had time to fly with my panel yet so I don't know if the G3X could do this but it would be more then awesome if the G3X could keep track of the weight and balance as you are burning fuel. Another words as you are flying and fuel is being used that the screen would show you at all times where your balance is without you having to add numbers to it.
I could see this being very helpful in the rv10
cderk 05-24-2016 11:34 AM
Just playing devil's advocate... why would this be helpful? During your flight planning, you should already know your weight and balance for takeoff and landing. If you know you are within limits at take off and landing, why would you need the system to calculate it for you anywhere in the middle?
Rick_A 05-24-2016 01:43 PM
Originally Posted by g3xpert (Post 1081774)
Hello Rick,
Steve
Steve, is there a way to get the baro displayed on one of the User selected data fields across the top of the display? It didn't come up as a selectable field when I customized the data bar.
luv2flypilot 06-09-2016 12:57 PM
G#X Touch Wish List
I also like the option for an "Oil Timer" so that it is easy to verify when an oil change is coming due rather than comparing the tach time to my log book.
The other option I would like is to have the flight timer automatic and not have to activate it. I find myself forgetting to turn it on on take off and my old GTX-330 transponder had a timer that automatically started on take off.
g3xpert 06-09-2016 05:31 PM
Hello Bryon,
Please look on page 330 of the Rev. F G3X Touch Pilot Guide. You can select the FLT time field to the top data bar which automatically and constantly shows the elapsed flight time.
We use it all the time. Comes in handy when referring to positions in our flight test videos.
Steve
rjtjrt 06-09-2016 05:55 PM
Originally Posted by g3xpert (Post 1086152)
Hello Bryon,
Steve
Steve
What parameters start and stop the Flight Time record? Is it speed, and if so what speed, or is speed user set?
John
luv2flypilot 06-09-2016 07:54 PM
Hello Bryon,
Steve
Steve,
I looked at page 300 and flight timer is listed but don't see how to make is start automatically? I have the flight timer set up to show on the top of my screens data bar but it requires manual starting. I must be missing a setup setting somewhere? Do I need to hold the menu button on power up and configure it somewhere in setup?
g3xpert 06-10-2016 05:25 AM
Originally Posted by luv2flypilot (Post 1086191)
Steve,
Hello Bryon,
Yes, as stated above, the FLT timer field is automatic. Nothing to do but select it to the data bar and enjoy it.
Please don't confuse this field with the totally different TIMER field discussed on page 29 of the Rev. F G3X Touch Pilot Guide. This is a manually operated timer that must be manually started/stopped/reset. Based on what you are telling us, you have enabled the TIMER field, not the FLT timer field.
Steve
Rick_A 06-10-2016 08:05 AM
Data Field question - ETED
Steve,
How does the G3X determine the Destination if one is trying to use the Estimated Time Enroute Destination? I never get a time display in that field, just blanks.
I'm using an external navigator (GTN 750) and the G3X doesn't seem to recognize the "Destination".
BTW. This G3X system is awesome. It's even better than I expected - way better.
Update: I went flying this morning and noticed the following: As I was returning home, I went Direct to 52F, so that was my next waypoint. The G3X was showing Blanks in the ETED field. While enroute, I added an intermediate waypoint. After adding the intermediate waypoint, the ETED filled in with a valid time to destination.
luv2flypilot 06-10-2016 08:21 AM
Originally Posted by g3xpert (Post 1086247)
Hello Bryon,
Steve
Ok yes I was getting the two confused. I will go back and set up the FLT flight timer on the data bar field and remove the timer. Thanks for the clarification.
rjtjrt 06-10-2016 06:18 PM
With Automatic Flight Timer, what parameters start and stop the Flight Time record?
John
g3xpert 06-10-2016 06:31 PM
Hello John,
This is also addressed in the description of the flight log feature in the G3X Touch Pilot's Guide. If your G3X system installation includes engine monitoring, the flight timer will automatically increment whenever the engine is running. Otherwise, flight time recording is determined based on altitude gain and airspeed as described here:
G3X Touch Pilot's Guide - Appendix B (page 335, ref F)
Flight Log
With EIS items configured, recording begins when the engine hours timer or airframe total hours is running. This allows recording of time spent on ground before takeoff and after landing while the engine is running.
With no EIS items configured, recording begins when the aircraft reaches 250 feet of altitude. When the aircraft’s groundspeed drops below 30 knots, the flight entry is saved and a new entry is recorded when departing the airport. A touch-and-go or brief stop of less than 10 minutes appends to the current flight record, rather than starting a new entry.
- Matt
g3xpert 06-13-2016 09:17 AM
Originally Posted by Rick_A (Post 1086288)
Steve,
Hello Rick,
Glad to hear you are enjoying your G3X Touch system. Upon investigation, it appears that the GTN does not output "time to destination waypoint" data when performing direct-to navigation. We're not sure why it does this, but we should be able to add a workaround in the next G3X software update. Much easier than changing certified software!
- Matt
chasers03 06-14-2016 08:47 AM
G3X display colors
I like my G3X more and more as I get to know and manage its settings. This thread is helping us to realize that many of our wish list items are in fact available as you Experts tell us something we didn't know or hadn't read about in the several hundred pages of the Guide and Installation Manual.
I would like to change the color of the ground speed number. That maroon just doesn't show up like the white numbers. I wonder if others of you agree?
Mancival 10-23-2016 08:43 AM
Originally Posted by sneedrv-6 (Post 963474)
Would be nice if the highway in the sky boxes would show vertical navigation without an IFR navigator. If I engage the AP and select vertical navigation the AP will fly me to the ALT I selected however many miles from the airport I select. Why not show the highway in the sky boxes while decending? If the AP is flying the plane why not give the pilot another thing to cross check with the descent.
Also would be nice when I am on final at my very dark middle of nowhere field to see the boxes instead of just relying on ALT and vertical speed. We have no vasi and limited lights, if I could take advantage of the highway boxes it would be like having a vasi at the airport, don't have to have VASI to land but it is safer and better, another thing to cross check with ALT and what you see out of the aircraft.
Could also be used in an engine out situation guiding you to the airport, or a VFR pilot on top of a layer with an engine out, highway boxes could save his or her life giving vertical guidance to an airport.
I assume this feature is not included because Garmin does not want people flying a non published approach, but why take this feature away from people that could use it as a safety feature.
Hopefully I am totaly wrong here and this feature is available, and I just do not know how to use it.
Jason
RV-6 IFR Advanced Flight
Rans S-7 G3x Touch
On another thread a couple people asked a similar question, in particular why the g3x software doesn't allow for vertical navigation (vnav) were the pilot sets the descent angle (e.g. 3 degrees) as is the case on the g1000 and many other certified and non-certified efis. g3xpert wrote he would look into it, but never came back afaik. At the moment, the way vnav in the g3x works is that the pilot input a target fpm-rate and the g3x fixes the descent angle based on the speed of the plane around one minute before the top of descent, with no control and no visibility for the pilot of what this angle is. In particular there is no way that the pilot can reproduce exactly the same descent angle to a waypoint (or airport) on 2 different flights, despite setting the same fpm target on both flight (so if you have cleared terrain and obstacles on the previous flight, not sure you will clear on the second flight). The software modification would be extremely simple given the vnav function already exists.
Bugsy 11-03-2016 07:30 AM
will G3X touch drive GNS 430
Planning for panel upgrade.
I know the 430 flight plan and comm will drive the G3X, but Im wondering if I can select comm channel on the G3X will it change the freq on the 430. Also can a flight plan and/approach be selected on G3X and have them port to the 430?
Id like to move the 430 to the right side of the panel, which is doable if I can drive from the G3X.
Paul
g3xpert 11-03-2016 06:05 PM
Paul
Hello Paul,
Thank you for choosing a G3X Touch system for your panel upgrade.
Page 32-125 of the Rev. Z G3X Installation Manual provides a list of all the COM radios which may be touch tuned from the COM1/COM2 radio tuning areas at the top of the displays. Unfortunately, the GNS 430/430W does not support remote radio tuning.
If you have a GNS 430W and have wired the Connext serial interface shown on page 24-16, you may push a VFR flight plan over to the 430W from the GDU, but you can't load and activate approaches on the GDU, so it is just a convenience when you are flying VFR with the system.
When you are using external flight planning with the 430/430W, the flight plan, including any approach in use is automatically transferred to the GDU each time changes are made on the 430/430W
In summary, you will want to have your IFR navigator in a convenient location in the panel to support using all the features it provides.
Let us know if you have additional questions.
Steve
Thermos 11-29-2016 10:20 AM
How about the ability for the G3x Touch to listen to and display Emag/Pmag serial data? I doubt I'm the first person to ask for this, but I can't find it mentioned anywhere else in the thread or on VAF.
Dave
dweyant 12-15-2016 08:10 PM
Originally Posted by Thermos (Post 1130382)
How about the ability for the G3x Touch to listen to and display Emag/Pmag serial data? I'm sure I can't be the first person to ask for this, but I can't find it mentioned anywhere else in the thread or on VAF.
Dave
I'd love to see that. Don't have the panel space for the stand alone unit.
-Dan
Brantel 12-16-2016 07:24 AM
Dave
Being someone that has deciphered the PMag's serial protocol (with help from EmagAir), I doubt they will ever take this on as that protocol could use some help. Much of the protocol issues have roots in the hardware/firmware design of the PMag.
