Also can we all agree that there is very little use for the “combined” display? That’s asking too much, never mind! Fitz |
I would also enjoy the ability to select regional radar only on the main map page (or have it follow the setting from the WX page). I find myself frequently switching back and forth between the WX page and the map to get both regional-only weather and traffic at once.
Maintenance Items
I’d love to see a scheduled maintenance page where you can create a list of reminders for:
- Oil change - condition inspection - ELT - Pitot/Static Test - Transponder Check - VOR Check Just like in Garmin Pilot you can see reminders when you need a BFR or IPC, this page would pop up and show you when these items are due. |
Something that I really miss from my GRT that I would like on the non-touch is a secondary oil pressure alert that is for under 1000 RPM. While the low limit is 50 or 60 PSI, the limit at idle is 25 PSI. I have mine set for 50 PSI and I routinely get 49 PSI at idle (when fully warmed up) and don't like seeing the warning pop up as I pull the throttle back to idle coming over the fence.
Larry |
I guess if I were king for a day at Garmin ...I’d be looking to see what it would take to install the HALO system aka Piper Autoland like the G3000 suite has. When you think about it most of the same inputs are going into the boxes. How hard would it be to update the software? With the way software and hardware are changing how soon could we see it in the experimental sector?
How about some 12” displays? That would be cool.
I would guess this is the big problem: in an emergency, you can do without the comms, and even the braking (keep it on the centerline, roll to a stop), but what about power? How do you get an airplane on the ground safely with power set for cruise or climb? So you'd need - at a minimum - a way to either control or (easier?) cut power. Either via ignition or fuel. System could calculate the glide (has enough data), choose a long runway, set up for dead-stick landing with adequate margins, cut power and land. Realistically, not very feasible now but in the future? Fun to speculate. |
+1 for reminders
Having a MX page with time since and user definable caution messages would be a welcome addition |
Autoland
We will need a FADEC controlled Lycoming + Garmin Auto Throttle
just an observation
All this talk about auto land...doesn't anyone fly anymore?
I have auto land available in my work aircraft, and it rarely gets used. Most times, maintenance is requesting one to keep the aircraft in certification... |
| All times are GMT -6. The time now is 03:26 PM. |
