Which engine and why??
As I begin putting the pieces together for an RV7 build, one question I can not get good results using the "Search" feature.
Which engine, and why? Being a previous AC owner, I am only familiar with names like lycoming and continental. And at first, the only potential engine I was going to consider was the Lycoming. However, after talking with some people, I hear companies like ECI (Titan) and others are also respected, known, and reliable engines. I (like most) want a great running and bulletproof engine. I am not interested in used. So I appreciate your feedback. I am not trying to start a "brand war" but could use your knowledge. Thank you in advance! Chad |
Chad,
If you still have couple years before buying the motor, go and physically visit all engine manufacturers of your interest. You will answer all your "which and why" questions based on those tours. |
Hopefully I am not a couple of years away :) Physically going to visit is probably not a possibility, however I am going to try and make Osh this year. No offense, but I hold more value in to what the members of what this forum say, than what the manufacturer says.
FYI... lost some faith in ECI this past year. My IA friend was doing an overhaul for a client on an engine here in Texas. Bought parts and crankshaft from ECI and preformed the engine build. All tags were verified as to part numbers requested and tagged provided by ECI. Turns out the crankshaft was identified and tagged incorrectly by ECI. Well this required another teardown, wait and wait for the correct part and a rebuild period taking weeks and weeks. ECI would accept ZERO responsibility for their error. That has cost them a ton of business in our area. The word spread quick here. If they would have stood up to their error... people make mistakes, things would have been much better for all. Sad
Reiley,
Thanks for that input. That is disappointing to hear. How did the engine perform otherwise? Was the crankshaft replacement premature or expect wear and tear? In other words, what would your opinion be if they had not misidentified the crankshaft? Thanks again! Chad |
Aerosport
Call Aerosport Power, http://aerosportpower.com/Vans_RV.html Great reputation!
Chad gives a great breakdown of choices here at his website: http://www.rv7factory.com/engines.php My opinion alone, IO-360 for the 7 or 8. Some folks go bigger, more weight and HP. I'm getting the Superior IO-360, cold air horizontal sump for my -8. Cheers, Don |
Don,
I am confused (admittedly not hard to do)....you sent me to Aerosport, but you are getting a Superior?? Thanks! Chad |
CHAD!!!!!
Alaska Bob here! I have an RV-7 with a Lyc IO-360, Blended Airfoil prop, and Electronic Ignition...full inverted system. Very many great choices for powering an RV. My face is in constant pain from smiling! Send a PM with your email and I'll get a photo to to you. Miss the Las Vegas jet event...and you. Bob |
| All times are GMT -6. The time now is 12:42 PM. |
