VAF Forums
-   Interiors (https://vansairforce.net/community/forumdisplay.php?f=89)
-   -   Interior installation timing (https://vansairforce.net/community/showthread.php?t=121357)
scrollF4 01-06-2015 07:56 AM
Question for the gang:
When should I install my interior? I know I should leave everything out except the seat cushions when I present N260KM to Mel for airworthiness. And I know I should at least set all the carpets and pad backings in the airplane when I run the weight and balance. However, what's the best time to go ahead and install it?
Abby (Flightline Interiors) made a beautiful interior, and I look forward to seeing it in the airplane.
scrollF4 01-06-2015 07:58 AM
....or should I present the airplane with the interior installed minus the removable panels?
Mel 01-06-2015 08:06 AM
The seats will need to be out for inspection. I will need to crawl through the interior inspecting all control and fuel connections from the firewall to the tailcone.
scrollF4 01-06-2015 08:10 AM
Thanks, Mel.
So is it OK to go ahead and install the wall and floor carpets? IE, any carpet that doesn't cover a removable panel?
rleffler 01-06-2015 10:24 AM
Originally Posted by scrollF4 (Post 947782)
Thanks, Mel.
I have a different model RV, but I don't think that makes a difference. I left carpet out until after a few flights. I wanted to ensure that there weren't any leaks or drips that may have been induced during the early part of Phase I.
It turned out to be a good approach, like many others have experienced, I had a o-ring in a brake cylinder start to leak after a couple flights.
bob
bruceh 01-06-2015 10:28 AM
I've been flying now for over 80 hours and I still don't have any interior - just seat cushions.
Abby gets them later this month to upholster and I can't wait!
Mel 01-06-2015 10:48 AM
Thanks, Mel.
Not a problem for me!
Sig600 01-06-2015 11:53 AM
Thanks, Mel.
You're gonna be crawlin around fixing things and inspecting for leaks for s few hours. I'd leave it out until you know that once it's in its staying in.
scrollF4 01-06-2015 05:22 PM
I copy all...thanks!
Mike S 01-06-2015 05:30 PM
So, with questions like this----------can we assume that your are seeing light at the end of the tunnel??
