VAF Forums
-   Interiors (https://vansairforce.net/community/forumdisplay.php?f=89)
-   -   Air conditioning removal? (https://vansairforce.net/community/showthread.php?t=121180)
rotoiti 01-01-2015 03:11 PM
I have purchased a flying RV that is equipped with air conditioning. I live in CA and have a limited use for air conditioning. I'd rather get rid of the extra weight and remove the compressor upfront and condenser/blower unit from the tailcone. I would like the procedure to be reversible (so that if I sell the plane I could put A/C back in if the buyer so desires).
Have a few questions related to that:
How do I dispose of the CFC coolant responsibly?
When I remove the compressor from the engine alternator pod, do I need to put some kind of a lid there? If so, what kind?
Other opinions welcome (i.e. I should leave it in but I'd love to hear why).
Thanks!
Wayne Gillispie 01-02-2015 08:38 AM
On the refrigerant question...Call your local HVAC or Refigeration guy to recover it.
Mike S 01-02-2015 08:46 AM
It may help if you give the model of RV, and the brand of A/C unit, as well as some photos.
Just off the top of my head, keep in mind C/G issues, and will the removal effect how the cooling baffling is set up.
Good luck, and congrats on your new bird.
woxofswa 01-02-2015 09:13 AM
I have A/C and love it. I use it considerably more than I anticipated. We had it on over half the time on our OSH trip. Granted I live in Arizona, but my rv10 heats up fast when the sun is direct on the windscreen even with moderate temps. It's nice for removing humidity as well which should cut down the musty smell aircraft acquire over time. Since these are traveling machines you never know where you'll end up.
rotoiti 01-02-2015 10:32 AM
It's a -10. AC is Flightline AC, their first model, discontinued since 2008, if I understand correctly.
Compressor picture: http://goo.gl/8ZlAHX
Tailcone picture: http://goo.gl/N9v3Lx (before it was closed up)
(pics courtesy of the original builder).
Although the plane is flying fine, I worry that so much weight so far in the tail moves CG too far aft if I load an adult or two in the back seats. Perhaps this worry is unfounded though.
1flyer 01-02-2015 10:52 AM
Shouldn't be too hard to figure out. You have the weights and moments of the AC equipment so just run a W&B problem with the two adults included and then run one with the AC equipment numbers removed. Compare the CG's and you'll have your answer.
rotoiti 01-02-2015 11:11 AM
I don't have the weight of the AC equipment in the tail. I don't have the distance from datum either but I can easily measure that.
Does anyone know the weight of the condenser/blower of Flightline AC? If not, I'll email John Strain and ask.
Wayne Gillispie 01-02-2015 12:10 PM
You should have received the W&B from the seller/builder which should include the air conditioning. If you have the EW, EWCG and datum it should be easy to figure out whether you are within weight/CG limits. Van's provided the CG range and a "recommended gross of 2700 lbs".
I would say even without baggage and especially if you have a lightweight prop, it could be very easy to exceed your aft limit. Even after ensuring you do not exceed any limits on paper, it is best to perform some SOLO flight testing using secured ballasts like some of us did during phase 1. You will be surprised how light it becomes in pitch and how an aft CG affects takeoff/landing/stalls. Be careful and enjoy your new bird.
http://www.faa.gov/regulations_polic...-h-8083-1a.pdf
MeAndMyToys 01-02-2015 12:11 PM
Start from scratch
I would get some acurate scales and weigh the airplane and do your own Weight and Balance. That way you KNOW where your at and how you can load it.
woxofswa 01-02-2015 12:36 PM
My A/C is CG neutral with the condenser on the belly, but I don't think the Flightline system is very AFT biased or they wouldn't have sold any.
My advice would be to do your own CG calcs and then fly with the system for a year and see how you like it. If you still want to remove it, you can remove the front or aft depending upon CG needs or both. If you remove the Aft components you'll have to cover the intake slot in the floor of the tailcone.
