Never Use Gasoline to Clean Wheel Bearings???
In the process of annualing the Mooney my partner claims that you should never use fuel to clean wheel bearings. We used Varsol.
Of course ever the skeptic I said "You dont really believe that do you? all the solvents basically do the same thing" He said it was because gas washes the oil from the pores. Is there any truth to all that? and why would it matter? I suspect 90% of car bearings get washed in gas and they run 100,000 miles. Of course its a fire hazard, and carcinogenic, and might cause my pet rat to have birth defects if he swims in it everday, who cares? I am flying experimental airplanes, riding motorcycles, drinking booze, eating steaks! ....I'll consider myself lucky to live to 85 then die of a rare cancer! What do you guys use to clean your bearing?..... |
I wash the airplane bearings in whatever solvent the mechanic has in his parts washer (I do owner assisted annuals on the 170/172 - still building the -8) It sure smells like mineral spirits but I'm not sure. T. |
I never wash out my bearings. (unless they fall in the dirt) I just REPACK them with new clean grease. |
Should the question be, "How often do the bearings need to be cleaned?". Just how many miles do we put on our gear in, say, 100 hrs. or so annually? The bearings seem fairly substantial, and I know they need to take high shock loads. I also know the grease will get dirty or can break down with age, but I just feel silly cleaning bearings each year, especially since they look fine upon disassembly.
I know I'll hear the chorus, saying it's a little inconvenience, just go ahead and do it. Still, I'm... Just wondering, Mark |
I use low odor mineral spirits, but wouldn't hesistate to use 100ll. Gasoline (reformulated) just stinks way too much to use, but would work well.
The point of cleaning the bearings, if necessary in the first place, is to get them totally and absolutely clean. Leave no residue whatsoever. Gasoline, a petroleum product, does a nice job of cleaning the conventional greases typically used in wheel bearings. One point of cleaning the bearings is to visutally inspect for spalling or other damage. Otherwise, Gary's suggestion of just repacking is reasonable. I used to clean and repack mine annually when based at a grass strip. But now that I'm on concrete 99.9% of the time, flying about 75 hrs a year, I'm rethinking this. Speaking of an odd wheel bearing situation. I have two GM vehicles, both '02 models. The front left wheel bearing on both vehicles - pickup and Suburban - failed within a month of each other at about 80-90,000 miles. Never heard of a car wheel bearing failing for no reason before. These did. Both sealed type brgs and completed wiped out. That set me back about $450 apiece. But I can change that spindle assy out fast, now. |
my z28 has 229000 miles on the front wheel bearings and no issues however a rear axle brg is finally making some noise. clean it with what ever you want just use high quality grease that can withstand high temps generated by the rotor if youve ever practiced short field landings at night youve seen a glowing red rotor. :) note : the yukon is up to 120000 miles with not as much as an airfilter. still on its second set of tires. oops i lied i did install a battery guess its time for an annual. ;) |
Washing with gas
Ahhhhhh!!! DON"T DO IT, use varsol or any other parts cleaning solution.
I come from a small town and when I was a kid used to hang around the B/A garage....The old mechanic there always had a pail of gas sitting in the middle of the shop for washing parts,hands or anything else needing cleaning..He lived to a ripe old age...go figure ! I am also a firefighter and have gone to several calls where the person (one victim) were: - cleaning motorcyle parts in the basement.... with gas - cleaning oil off the floor of the shop....with gas - kabooom I know that a lot of people still use this practice for cleaning parts......why ? It ain't that much cheaper.....Is a LOT more dangerous......and WILL eventually ruin your day. Safety should be a priority as we are building our RV's......we go through a lot of pains to Fly Safe......Lets "Build Safe" too. stepping off the soapbox now... |
Anyway, I've been told that a good shop cleaning solution is one gallon of "Gunk" with five gallons of Mineral Spirits (this is for a typical shop parts washer). I've also been told that OSHA no longer allows this mix - which means it must work. John |
-mike |
I used whatever the mechanic had.
Used to clean and repack the bearings every year but lately have skipped a year in between as I haven't been flying the 172 very much.
| All times are GMT -6. The time now is 06:00 PM. |
