Bendix RSA fuel servo
I have about a 45 GPH flow rate to the servo, but only 6GPH coming out. Yellow tagged, hasn't been run, waiting for plane to be finished (ten years). I checked finger screen and it is clean.
Any guesses? |
Mixture lever run both ways-------make sure it is full rich.
If you are not running it on the engine it is not sensing airflow and therefore limited fuel on the idle circuit only.
Why not finish airplane instead of screwing around with the servo? Unless you have a servo test setup you'll learn nothing. Bendix does advise running fuel to it when mounted to a engine that will not be run for a while. Seals can deteriorate.
This will create pressure in the intake track, but not flow. Doesn't the servo measure air flow?? |
As others have stated, without a good flow bench or test rig, you don't have much to "test" here or learn other than if it is working at it's basic level or not. Wait until you start the engine, then you'll find out quickly how the idle mixture is set, how the flow is once you're off the idle circuit, etc.. Not easy to do on the bench without more specific tools. Just my 2 cents as usual. Cheers, Stein |
Solved
RV Dan and Dan Horton nailed it. Without engine running, that is all the fuel you will get out of it(I spoke with a overhaul shop). Plane is finished, getting ready to start it and awaiting inspection. Picture of it is in RV4 area in "status" section.
If you are really concerned about it, send it down to Don at Airflow Performance in SC, he's the fuel injection guru and can tell you everything you need to know about yours, will do a complete test for a reasonable price and provide a flow chart as well.
I sent him my complete fuel system (RSA-5) from the servo to the injectors for overhaul, my Lycoming as never started easier or run smoother (hot or cold) than it does now, I am very pleased with their work. All the best, Reggie |
Ran the engine the other day and it fired up flawlessly. I later did a full power run up and the fuel meter was showing 17gph... can't wait to fly it.
| All times are GMT -6. The time now is 04:34 AM. |
