VAF Forums
-   -   RV-6A Accident - Melbourne Australia - 14 Oct 2014 (https://vansairforce.net/community/showthread.php?t=118555)
Ignition 10-13-2014 11:46 PM
Approx 3 hours ago, an RV-6A crashed into a building in Melbourne's South East (Australia). The aircraft had just taken off from nearby Moorabbin Airport and was cruising down the coast at approx 3000ft at 1:26pm - unfortunately the pilot is deceased.
It appears on radar that in approx 5-6 seconds, the aircraft had lost 500ft, and a further 15 seconds later, impacted the ground. A loss of 3000 feet in 20 seconds - around 6-9000 fpm descent rate and increasing.
The ATSB are sending investigators to the scene to determine the cause - ATSB file can be found here: http://www.atsb.gov.au/publications/...-2014-164.aspx
KRviator 12-02-2014 06:32 PM
The ATSB Update (Part 1)
Originally Posted by The ATSB
History of the flight
On 14 October 2014, at 1321 Eastern Daylight-saving time,[1] the pilot of an amateur‑built Van?s RV-6A aircraft, registered VH-JON and being operated in the ?Experimental Category?, reported taxiing for a local flight at Moorabbin Airport, Victoria. The aircraft was subsequently cleared by air traffic control for take-off from runway 17 Right at 1323 and to maintain runway heading to depart the control zone to the south. The aircraft was then observed on Airservices Australia surveillance radar climbing to 2,900 ft above mean sea level (AMSL) and tracking southbound via the coast, in accordance with the published departure procedures for Moorabbin Airport. After 1326:07 no further radar returns were received from the aircraft.
The aircraft was observed by witnesses descending rapidly before impacting the ground next to a house in the suburb of Chelsea, 8 km to the south of Moorabbin. The aircraft was destroyed by the impact and the pilot was fatally injured.
There were a number of small post-impact fires started by the accident that were subsequently extinguished by members of the public and the fire brigade. A number of houses and several cars also sustained significant damage as a result of the accident.
Pilot information
The pilot held commercial and private flight crew licences with an aeroplane category rating. The licences were endorsed with single- and multi-engine class ratings and design feature endorsements for manual propeller-pitch-control and retractable undercarriage. The licences were also endorsed with instrument flight with 3-dimensional and 2-dimensional instrument approach privileges and night visual flight operational ratings. Both ratings were restricted to single-engine aircraft.
The pilot held a current class 2 medical certificate, which meant that the pilot could only exercise the privileges of a private pilot licence. The certificate included restrictions that distance vision correction was to be worn by the pilot and reading vision correction was to be available while exercising the privileges of the licence. The pilot last underwent an aviation medical examination 12 days prior to the accident. During that examination the pilot reported a total of 1,659 flying hours, with 17 hours flown in the last 6 months.
It was reported that the pilot appeared to be well rested in the 72 hours prior to the accident. No medical or other issues were reported to family members by the pilot in that period.
Aircraft information
Civil Aviation Safety Authority records indicated that the aircraft was constructed in 1999. It was first registered as an amateur-built aircraft in 2003 by the pilot, who was also the registered owner and operator.
A search of the Australian Transport Safety Bureau (ATSB) occurrence database revealed that the aircraft was involved in two previous accidents. In 2007, the aircraft sustained an engine failure and damage during the resultant forced landing. The Honda V6 engine that was installed at the time was reportedly removed and a new Lycoming IO‑360 aircraft engine installed in its place. It was also reported that the damage was repaired and the aircraft returned to flying status.
The aircraft was again damaged during a landing accident in 2010 when the nose wheel collapsed and the propeller contacted the ground while the engine was running. The engine was reportedly replaced with another Lycoming IO‑360 engine, the damage repaired and the aircraft returned to flying status.
The aircraft was also reported to have been involved in an incident approximately 1 month prior to this October 2014 accident, when an engine fire occurred whilst the aircraft was taxiing at Moorabbin. The fire was extinguished with the assistance of other persons. It was reported that the engine and associated areas of the aircraft were inspected by the pilot, who reported to friends that there appeared to be no damage as a result of the fire.
Aircraft refuelling
None of the mobile refuelling agencies at Moorabbin reported supplying fuel to the aircraft on the day of the accident.
The Dynon EMS-D120 engine monitoring system fitted to the aircraft recorded data relating to the total amount of fuel on board (see the section titled Onboard recording devices). The last system-recorded date of an increase in the amount of fuel on board coincided with the last recorded date that the pilot purchased fuel (AVGAS 100 low-lead) from a self‑service bowser at Moorabbin.
The EMS-D120 data showed that the aircraft completed three separate flights over a period of about a month after that refuelling, totalling 2.1 hours. This did not include the accident flight.
Weather information
The weather conditions at the time were reported to include a moderate to strong southerly wind at 17 kt, with some mid-level cloud in the area. Visibility was reported to be greater than 10 km. These conditions were consistent with the forecasts for Moorabbin and the greater Melbourne area.
Communications
Examination of the recorded air traffic control radio transmissions for Moorabbin Tower and the associated flight information service frequency to the south of Moorabbin revealed no emergency broadcast from the pilot. There was no evidence of any partial transmissions, open‑microphone transmissions[2] or over-transmissions[3] during the flight.
Aircraft wreckage information
Wreckage examination
The aircraft impacted a house fence and adjoining laneway in a significant nose-down attitude at high speed. The initial impact was to the left wing, which indicated a left wing‑down attitude of about 10? at the time. Witness marks on the fence indicated a descent angle of about 35?.
The aircraft commenced breaking up after the initial impact, with the left wing remaining at the initial impact point and the remainder of the aircraft continuing along the laneway. The propeller and engine separated from the fuselage and came to rest approximately 48 m and 68 m respectively from the point of impact.
The vertical and horizontal tail surfaces also separated from the fuselage and from each other and were located along the wreckage trail. The right wing and remainder of the fuselage came to rest approximately 95 m from the impact point but remained largely intact.
The remainder of the aircraft, including the cockpit, was destroyed during the impact sequence. Items associated with the aircraft were located in the laneway up to 130 m from the point of impact.
All flight controls and major aircraft components, including the cockpit canopy, were identified at the accident site.
Examination of the fuselage revealed considerable oil coating on the external surfaces. Oil was also found on the upper surface of the right wing and right horizontal stabiliser (Figure 1). There was very little oil coating on the left horizontal stabiliser and none on the left wing. Examination of recovered fragments of the cockpit canopy also showed oil coating on their internal and external surfaces.
Figure 1: Horizontal stabilisers displaying right stabiliser oil coating
Source: ATSB
The engine and propeller were recovered for later technical examination under the supervision of the ATSB.
KRviator 12-02-2014 06:33 PM
The update - Part 2.
Recovered items
A number of aviation-related items were reported recovered at distances of up to 3 km from the accident site by members of the public and handed in to Victoria Police (Figure 2). These items included the pilot?s flight crew licence and aviation medical certificate, an aircraft pitot cover and warning flag, a flight bag, an En Route Supplement Australia (ERSA)[4] and a very high frequency (VHF) handheld transceiver and antenna.
Figure 2: Location of recovered aviation-related items relative to the accident site
Source: ATSB
Recorded information
A number of electronic devices were recovered from the aircraft wreckage with the capability to record in-flight data. These included two Garmin global positioning system (GPS) units, a Dynon EFIS-D100 electronic flight information system and a Dynon EMS‑D120 engine monitoring system.
GPS units
Initial examination of the GPS units revealed significant damage. Further detailed examination is required to establish if any data can be recovered from either GPS.
EFIS-D100
Examination of the EFIS-D100 unit revealed that it was not configured for data logging. No relevant data was recovered from this unit.
EMS-D120
The EMS-D120 unit logged data from the accident flight. This included the aircraft?s GPS ground track and derived ground speed (Figure 3). When compared to the recorded radar data, the GPS ground track was consistent with the aircraft?s recorded radar track. No altitude or airspeed information was logged by the unit.
A number of engine operating parameters were also recorded by the EMS-D120.These parameters revealed that the engine appeared to be performing normally during the take‑off, climb to altitude and short cruise period. Work is ongoing to explain a decrease in the engine oil pressure about 7 seconds before the end of the recorded data.
The last valid data logged was time stamped at 1326:00.[5] The corresponding GPS position showed the aircraft approximately 640 m to the north of the accident site at that time.
Figure 3: Recovered data from the EMS-D120
Source: ATSB
Closed-circuit television footage
Closed-circuit television (CCTV) footage of the aircraft as it taxied at Moorabbin that day revealed no apparent anomalies with the aircraft. The aircraft?s cockpit canopy was in the lowered position at that time.
Other CCTV security cameras at Chelsea captured the last seconds of the flight. Analysis of that footage confirmed a steep nose-down flight path and an aircraft speed of approximately 200 kt (370 km/hr) leading up to the impact with terrain.
Radar data
Examination of the recorded radar data showed the aircraft climbing out of Moorabbin on runway heading at 1323:53. Twenty-eight valid radar returns were recorded for the aircraft, which was transmitting radar transponder code 3000.[6] The last valid return was at 1326:07 and indicated an altitude of 2,500 ft. Other traffic in the vicinity was detected by radar at altitudes as low as 1,100 ft.
Further investigation
The investigation is continuing and will include examination of the:
?engine and propeller
?cockpit canopy locking mechanisms in a number of similar aircraft
?construction, maintenance and repair history of the aircraft
?viability of recovering additional data from the accident‑damaged GPS units
?radar data from a number of additional radar heads to determine if any further returns were recorded from the aircraft
?pilot?s medical and flying history.
Infidel 12-02-2014 07:05 PM
Very sad to read and seems to me, that -6 had some bad mojo. Not that I'm superstitious but, sometimes we have to wonder.
ijustwannafly 12-03-2014 09:28 AM
Very sad indeed and unfortunately we may never know what really happened :(
aarvig 12-04-2014 11:41 PM
Wow, both the Canadian and Australian accident reporting authorities put out very through reports. Especially relative to the NTSB. I wonder why that is?
My thoughts and prayers to all involved in this crash.
E. D. Eliot 12-05-2014 12:21 AM
Guess that I missed it!
There was a fatal accident of an RV-12 in Australia on its first flight about a year ago. Guess that I missed the definitive report on the 'why' of this accident. Since I will build a 12, I'm very interested to hear the final Australian report if it is out.
Please advise - my info on this accident is about 6 months old.
Richard Connell 12-05-2014 01:50 AM
Here you go.
http://atsb.gov.au/media/4469487/AE-2013-069_Final.pdf
PIN 37 12-05-2014 03:19 AM
Not actually sure I know what that says, can anyone dissect that and tell me what happened. Here in Oz we have heard rumours, .... but lets talk about it.:confused:
PS. I have made a changes to the trim on my RV7 based on the "rumours" about what caused the RV12 crash
RV10inOz 12-05-2014 04:14 AM
The RV12 was nothing but showboating/ cowboying and predictable
Don't worry about yours though.
Richard Connell 12-05-2014 04:29 AM
I'm not sure id be bothering to change the design of the trim system in a 7 based on that report. What have you changed?
Gets airborne, trims forward and accelerates just above the ground, pulls up (while re trimming) and stalls.
My interpretation is deliberate pilot action for reasons unknown. I see no trim failure mode that could replicate that. Others may have different theories.
Very sad. :(
PIN 37 12-05-2014 04:57 AM
No trim run away????
I have put in a system that prevents trim run away, saw it here on VAF, cant remember what it is called, but was cheap and seemed like a good idea to me.
Called TCW saftey trim
BillL 12-05-2014 07:38 AM
Condolences for friends and family.
Am I reading this report correctly? Oil is mentioned several times, and the data stream showed some oil pressure jags near the end of data. Oil on R/S wing and HS, oil in cockpit, oil on inside of canopy. Is there any further information yet? Choking oil fog, fumes in cockpit - canopy opened resulting in evacuation of paperwork etc - - - is that the implication from the facts given?
I can not see if the pilot was wearing a chute. Maybe I missed it.
Joness0154 12-05-2014 09:31 AM
My guess is that the low volume of accidents in Canada/Australia in comparison to the US.
simpkinsona 12-05-2014 11:17 AM
Runaway trim is a serious problem in large aircraft. Not so in our RVs. You can safely fly an RV with the trim in any position.
-Andy
E. D. Eliot 12-05-2014 12:12 PM
Thank You
Thank you Richard and David for the report. I've been looking for answers to this accident ever since it happened and appreciate the info. My condolences to all involved.
If it hasn't been done already, I'll post a note about this report of this very sad accident into the RV-12 blog.
Kevin Horton 12-05-2014 12:59 PM
I can?t speak to Australia, but I know that in Canada the TSB does not do much of an investigation for most private general aviation accidents. There isn?t much new to learn from most accidents, so a full investigation isn?t a good use of their limited resources. But, if they see an accident that looks like there might be something new to learn, they do a proper investigation.
kiwipete 12-05-2014 01:14 PM
Trim movement
I think without further investigation that the trim readings can't really tell anything.
The report says the trim units are read by the dynon as a figure of +1 to -1 the trim is shown to go from -.015 to as low as .027 then up to .005
Without knowing if the travel readings at the full deflection were +1 to -1 these readings may have been as little as 1% of the travel. The trim may have just been experiencing normal air loads not actually been moved? You need to know the full scale of movement.
Maybe someone with an dynon sky view on an -12 might be able to answer.
Peter
Richard Connell 12-05-2014 03:30 PM
Fair enough Phil,
I've had a few trim incidents over 500hrs in my 7. Mainly maps resting on the trim switch and the like. I also blew a fuse once and had the trim stuck in full nose up for a short local flight. Got my attention but certainly no big deal. I agree with Andy. Trim motor malfunctions in our aircraft shouldn't be a disaster.
The main issue with the -7 trim in my experience is that it's too sensitive at cruise speeds. So speed scheduling is a nice to have. I think TCW does that as well perhaps?
As it happens, I just replaced my original autopilot with the Garmin. The beauty of the Garmin GSAs is that they drive the trim servos. So now I have auto trim, speed scheduling and runaway trim protection (in both axes).
I don't think people should be fretting over any airframe malfunctions in the RV12 incident. Multiple witnesses, the flight data and I believe cockpit and external videos all point to the same conclusion.
Sounds like there is a fair bit of work being done on the Chelsea accident. No doubt because of its high profile location. Hopefully we get some answers in the near future.
Cheers
Snowflake 12-06-2014 11:17 AM
To add to this, as i've assisted the local TSB office on two accident investigations involving amateur-builts: In Canada the TSB works to obtain the best "bang for the buck" from their time and services. They will happily investigate amateur-built accidents, *if* there isn't a "higher value" task at hand.
Generally there are enough commercial incidents involving an aircraft type that's widely in use (Cessnas, Beavers, etc.) or accidents likely to involve large numbers of the paying public (Airliners) to keep them busy... Any smoking guns they find there are more likely to maximize the numbers of lives saved if they focus on those high value targets. One- or two-off amateur-built designs, in contrast, get little attention unless others from the aviation community offer to assist (that's how I got involved).
The TSB has done excellent investigations on at least one RV accident that i'm aware of (an -7A inflight breakup) when staff were available. I suspect the fact that RV's are becoming a significant part of the amateur-built fleet in Canada may also contribute to their interest in investigating... Despite the wide variety of builder modifications applied during initial construction, in general the basic structure matches the plans on the majority of RV's.
For those in the US who feel they aren't seeing much investigation happening, it might be an option to offer to help. There is a lot of builder expertise in the RV community, and the knowledge base may not exist in the local NTSB office. You may find (as we did) that the local office was very keen to learn, and welcomed the assistance.
I'll caution though, that accident investigation isn't for everyone... Especially when it comes to investigating a fatal accident.
RV10inOz 12-06-2014 03:52 PM
Same applies here, although lately they have been trying t do them more often. Less QF32's to work on maybe?
