VAF Forums
-   -   0-540 Throttle and Mixture brackets (https://vansairforce.net/community/showthread.php?t=118410)
TrueAirSpeed 10-09-2014 08:46 PM
For those building RV-10s with a carburetor instead of fuel injection, what is your source for the throttle and mixture control bracket?
Jesse 10-12-2014 12:47 PM
I know you don't want to hear this, but it's very much worth your while to go with fuel injection instead of a carb. The efficiency and control are wonderful. It's not that expensive and will pay for itself in efficiency.
TrueAirSpeed 10-12-2014 09:16 PM
Thanks!
Agree to a point.
N520TX 10-13-2014 08:18 AM
Vans
I was planning on one of these:
http://www.vansaircraft.com/cgi-bin/...rottle-bracket
--Ron
TrueAirSpeed 10-13-2014 08:24 AM
Tried the VA-182-PC
Didn't work .
n144sh 10-14-2014 01:09 AM
540 carb throttle / mixture bracket
Hi Terry,
I see you are building a bearhawk - great choice to go with an RV! I am working on a BH 4 place and flying my RV4 I built.
What I did for bracket on carb 540 is start with the Vans bracket and did a bit of fabrication. A little cutting and welding but not bad.
Steve
rV4 completed
Bearhawk 4 place in process
TrueAirSpeed 10-14-2014 07:28 AM
Thanks Steve!
I have fabrication as an alternative, but thought I would look for off the shelf first. Thanks again and good luck.
