How to start the engine
Okay folks, I may be having an 60's flashback, but I somehow got it in my mind that the starting sequence for my IO360 M1B with AFP fuel injection and dual Plasma III ignitions was supposed to include hitting the starter for a couple of blades and then turning on the ignition. Can't find anything about that in the Lightspeed documentation nor in the AFP documentation. Did I imagine this?
Haven't done that trick since I flew the Pratt and Whitney round engines on Beavers. I would stick with the normal... prime if you have it.
Crank and crack if you don't. 1/4 cracked throttle... Judicious pump of the throttle if needed. If it backfires... keep cranking. If the ambient air is really cold....figure a way (lots avail.) to warm the sump prior to starting... good for the life of the cylinder barrels too. Nick |
Lots of info on getting an engine started, have not heard of what you are describing at least not for an IO-360 with dual plasma and AFP injection.
In most cases your engine will be running before you get a chance to look at the second blade:). that is, if you turn the ignition on before cranking like most everyone else. I see you are in San Ramon, is your RV located in Concord or Livermore? Hope to meet you, lots of RVs on both of those airports. |
Starting
With Purge valve.
I prime the engine 5-6 seconds with purge valve, WOT, reset throttle to about a quarter inch open, engage starter and push purge valve in at the same time.
Same procedure with hot engine except no prime. Engine usually starts with a couple blades swung, sometimes more with hot start. It's an art, getting the engine started. In time you come up with what works for you. Amount of prime takes practice, priming with throttle closed does not work for me. Bypass flow rate is too slow. With WOT it is at least three times and gets fuel up there in 5-6 seconds. Do the same thing with throttle closed and my engine won't start. |
I haven't seen a recommended procedure to motor the engine with mags off on a horizontally opposed engine. Doesn't mean it isn't out there but I haven't seen it. Different story on round engines.
Permanent magnet starters in particular draw a very large amount of current at low rpm. The current decreases as the rpm increases, which means the voltage goes very low when you first hit the starter, then it comes back up as the engines starts to turn. So, if you have a PM starter, and an older Plasma ignition (as I do), the recommended procedure is to hit the starter button with the ignition off, then turn the ignition of after a couple of blades. My kickback issues went away when I adopted this start technique. Apparently the newer Plasma ignitions have a design change that makes them more tolerant of low voltage, in which case it is proably OK to have the ignition on before you start cranking. |
I've heard of people with lightweight props doing that to prevent kickback.
Best, |
| All times are GMT -6. The time now is 04:35 AM. |
