CHTs vs OAT
When testing the effects of cooling modifications on CHTs, is there a way to "normalise" OAT? In my experience the same climb at the same speed and weight on a 60 degree day and on a 100 degree day will not yield exactly 40 degrees increase in CHT at the same final altitude. This could simply be flawed observation on my part...
Do humidity and pressure come into play or are the differences minor (less than 5 degrees to my way of thinking when looking at temps between 350 and 430 degrees). |
I got the the answer from Kevin Horton in another thread...this is cross posted in the flight testing section for the archives.
Kevin's is (not surprisingly) the same as the Lycoming chart. I just did the back calculations a few days ago to see how they plotted the cooling curves.
Good luck. |
Air density is an important factor. Some certified turbocharged aircraft have their service ceilings limited by cooling difficulty at high altitude, despite the fact that it is cold at those altitudes.
| All times are GMT -6. The time now is 04:42 AM. |
