What is the RV-6A firewall gauge and metal type?
What is the RV6A firewall gauge and metal type?
I'm looking for the spec and can't seam to find it in the blueprints. |
I'm not sure on the -6, but on the -10 it is stainless steel and about .020-.025". I don't know what gauge that works out to be, but it is surprisingly thin. I assume the -6 and -10 are the same.
Firewall
My 6A is stainless steel and I believe it's .020. Can check with a mic tomorrow if you need exact thickness.
From the plans
The RV-6 plan sheet 25 calls out Type 304 18-8 stainless steel 28-26 ga. for the firewall.
That would make it 0.015 to 0.018 inch thick. |
| All times are GMT -6. The time now is 12:28 PM. |
