Which GPS numbers to use
Which of these gps coordinates do I enter into my 430 to find the place?
I am not up to speed on the differences between these degrees and decimal conversions. I think the 430 takes decimal and not degrees min sec. but Im not sure. And I dont understand the negitive number. Thanks, Mike 34-06-21.3530N / 084-26-54.7430W 34-06.355883N / 084-26.912383W 34.1059314 / -84.4485397 |
Strange.....
Hi Mike,
Those are some strange looking numbers.....where did you get them? Furthermore, all three lines appear to be different locations. :confused: I have three Garmins, a 95, 195 and GX55 and they take something like this: N33 21.496 W82 34.011 Did you add the hyphens? |
You can use the second format you listed, but manual mentions a few formats it'd accept (Position - Latitude/Longitude (degrees/minutes or
degrees/minutes/seconds), MGRS, or UTM/UPS). In the example you mentioned, - is for West (a positive number would be for everything east of 0 meridian). Also, that minus inbetween other numbers is just a "spacer".. you can just ignore that. |
It depends!
The GPS can be set up to accept a whole bunch of different lat/lon formats. On the 430, I believe you go to the third AUX page, then select Units/Position. There is an item in there that lets you choose either degrees-minutes-decimal or degrees-minutes-seconds.
good luck, mcb |
You can set up the GPS to use whichever format you choose.
Degrees-minutes-seconds Degrees-minutes-tenths of a minute Degrees-tenths of a degree The most commonly used is #2...degrees-minutes-tenths of a minute |
It's the same place
The are all the same location. Taking the N ones as an example.. First one 34-06-21.3530N is in degrees, minutes and seconds of an arc Take the seconds field (21.3530) and divide by 60 (60 seconds = 1 minute) 21.3530/60 = 0.355883 Second one 34-06.355883N is in degrees and decimal minutes - note the fraction of the minute is what we calculated above.... :) Take this whole minutes field (the minutes and the decimal portions) and divide this by 60 (60 minutes = 1 degree of arc) 06.355883/60 = 0.1059314 Third one 34.1059314 is in decimal degrees only And, guess what, this decimal portion of the degrees is exactly what we calculated above.... :D Back to skool for you...... ;) These are the SAME LOCATIONS, however the format needed for data entry into the Garmin 430 must be in the user's manual somewhere. On a wild guess, I would think this is programmable, and the 430 could take any of the formats. I seem to remember I use the second format with my GX55.. gil in Tucson - elementary mathematics (and geography) |
I can recommend using the calculator page at GPS Visualizer for coordinates conversions:
http://www.gpsvisualizer.com/calculators In the top calculator, you can enter coordinates in *any* format, and the web page will convert them and present them in different formats, either as separate lat/long, or as a single string. Very handyy when working with waypoint in Google Earth! I've worked with Alan Schneider providing him with feedback on the page, and he's done a great job. He surely gained his $20, which I gladly Paypal'd to him! And BTW, my take on the coordinates used by the Garmin 430 and all the certified panel-mount GPS is that they *must* be DM.m, as all the coordinates for waypoints and VORs/NDBs are expressed in that format. Of course my Garmin 296 uses three decimals after the dot, so there is much better resolution available. Ciao, Luca |
| All times are GMT -6. The time now is 09:14 PM. |
