Failed on the picture post
Something like this, only different:
https://www.youtube.com/watch?v=NN1yFR3i34M |
A/D to Catto
I recently, 1.5hrs ago, replaced my A/D 2 blade with a Catto 3 blade. I have been totally impressed. The pull on the runway is better, top end better, and when I pull the throttle to slow it down, the Catto seems to deaccelerate faster.
I am sold.... I have not been able to get real world numbers yet, maybe this weekend if the weather holds. Phil [IMG] [/IMG] |
What size A-D propeller did each of you replace ?
A/D to Catto
68" x ??
I will have to take another look when at the airport. I have a 160hp Lyc. |
Looking forward to your post of more info.
I am replacing a 68 x 78 A/D
I was concerned with the spacer configuration so I ended up just ordering new extension and spacers for the catto from saber. went with a 20lb crush plate as well that I will put on when my brothers want a ride. anyways, I got everything on the plane last week. will have to do the A/D numbers later though should be easy as I have all old spacer fwd setup I can just bolt on. I went for 2 short flights in the pattern as it was a busy week.... First impressions: on ground - prop looks amazing - Surprised that the prop felt no smoother than the old A/D - seems like more vibration under ~1200 rpm flying - Prop pulls hard on run up 2200 static iirc - no noticable difference on takeoff - on climbout the noise was much different then the A/D sounded like a 185 more like it was cracking the air (not sure how else to discribe) - Seemed to be more vibration in the downwind than the A/D though I may have been overly sensitive with new prop. - final / landing I couldnt really tell a difference, possibly slowed faster. I contacted catto and googled the potential vibration and noise - catto thought the increase in noise may have actually been hearing more engine noise bc of quiter prop. I may believe this - I have moved the prop 1 bolt hole clockwise to see about vibration going to try this afternoon and see how it is ![]() |
I was surprised to find that one hole move solved mine completely. Hope it does for you.
Aymar Demuth to Catto 3 blade
Neal,
I miss the Christin Eagle sometimes, but the RV is such a relaxing and fun plane to fly, I am glad I made the trade. Tell Tim hello for me. Phil |
OK, slow progress on getting real numbers but I do have close ones that I will narrow down in the next week or so.
This weekend I flew from new orleans over to the thomasville, GA fly in. Fun time nice group and great food. I only stayed for sat but many were camping over the weekend. so, on the way back 10,500 2400 rpm ~140mph ind /168 true 2500 rpm ~148mph ind / 177 true The A/D was ~10mph faster two things that come to mind, the three blade has a larger diameter nosecone and I am now running 20lb crushplate. would you guys expect these to reduce speed by ~10mph? just looking for similar experiences and thoughts. I am very happy with the prop and it is smooth now that I rotated 1 bolt hole clockwise (why this did anything I have no idea) |
A measure at WOT at the similar weather conditions and altitude. That would be your best static data point to start from. If you have accurate fuel flow and MAP measurement- use those also. Then you could measure similar power settings/conditions at what TAS. The RPM setting is a minor power data point with different prop comparisons since that will vary. |
You know I never thought about it, I have no idea what my power setting is with my setup ... Just picking rpm at altitude. I will get wot at altitude so then approx power setting is known.
| All times are GMT -6. The time now is 08:19 AM. |
