Not that the others haven't listed good things, but..
I had a similar problem and found this inside my SkyTec starter. ![]() It was close enough it would work most times. But sometimes it wouldn't... what a pain those problems are. |
Without knowing what terminals gave you the 6.5 ohms, I can't say for sure. I would not expect any resistance across the contactor at rest, IF the cables are removed. If not, you could be picking up resistance across a circuit in the wiring. |
it's the Skytec solenoid
It's most likely the solenoid on the Skytec starter. I had the identical symptom on mine soon after installing an overhauled starter. After sending it back to Skytec, they told me that they had a bad batch of solenoids with a manufacturing defect (burr) that prevented or slowed the movement of the plunger which activates the contactor and moves the pinion gear. Replaced the solenoid and all has been good for ~3 years now.
Heinrich |
Larry |
Some replies
Thanks for the input guys.
Here are some replies to your questions and suggestions: The wiring is as depicted on the "certified" drawing: In other words it's like it schould be with the ACS switch. Ground path: we've installed a separate ground wire with the same size as the starter wire (#2 awg I think?) This wire is installed on one of the four bolts holding the starter onto the engine. The other end of the wire is connected to battery negative. Ohm: the 6.5 - 7 ohm where measured across the two big terminals on the starter relay. I didn't think of measuring the ohm across the two small terminals. Sky Tech solenoid: I didn't think of the built in solenoid in the starter, but since the delay where still present when the starter-power wire where disconnected at the starter relay, my thoughts are towards the starter relay for now. Therefore, I've ordered a new one from Vans and it's on it's way over here. My plan is to install the new starter relay when it gets here. I'll also open the old relay and look for burned contactors inside. That'll be interesting! I'll post results and pics when it's done. BTW: on startup today, the starter engaged right away when the key where turned. That was the VERY FIRST TIME the starter had zero delay since the very first start a few months ago. That made me very happy, but a few mins later, my happiness faded away: we'd to turn back right after t/o due to engine roughness. That episode is described in another post here on the forum, so that's another story.... |
Update
Hi guys.
This is an update to the tread I started a while back: Two things has happened since then: 1) I have replaced the starter relay but the delay is still there. 2) The delay has gradually became longer: now it's 13-15 secs. Therefore, I have decided it's time to get to the bottom of this once and for all. Today, I did some more checking and here's the results: Immediately when the starter relay "clicks", there's power on the out side of the starter relay and the starter turns the engine. When I manually put 12V onto the starter wire, the starter immediately turns the engine. Therefore, it seems to me that the starter and the starter relay is OK. I measured the volts on the little terminal on the starter relay which receives power from the ignition switch through a small wire. I guess that's the terminal who makes the starter relay engage when you turn the key. (I have the A-510-2 ignition switch) There I discovered something strange: when I turned the key to "start", the volt on the little terminal showed 9,2V and then slowly started to increase. After approx 15 secs, the volt read 10,5 and didn't go further. (the starter key was held in "Start" position all the time) Then I made a new wire, and connected it from the terminal of the ignition switch and to the little terminal of the starter relay. The result was the same: approx 9,2V when the key was turned to "start" and held there. The volt climbed slowly to 10.5 and stopped. Finally, I took a wire and connected it directly from + on battery to the little terminal on the starter relay, and now the volt read 12,0 right away and stayed there. Based on these new findings, I'm thinking the fault is within the A-510 ignition switch. It seems to me that 9,2V on the little terminal shows that somewhere from the ignition switch and to the little terminal, there's some resistance who "steals" the volt. The wire from the ignition switch and the little terminal is short, so I doubt the fault is there. That leaves me with a faulty 510 ignition switch. Before ordering a new one, I'm wondering if any of you have some other ideas? Thanks. regards Alf Olav |
The ignition switch is the first place I would have looked for trouble. They have a well-deserved reputation for unreliable contacts. If you are feeling a little adventurous, throw out the ACS key switch and go with individual toggle switches for your mags and a push-button for the starter.
By the way, if your ignition switch contacts are bad, be VERY careful because your magneto P-Lead contacts in that same switch body may very well not be making reliable contact. Please be very careful as your ignition may be "live" even with the key removed from the switch. |
Dont know about that ignition switch but some are designed to be "push to Start" switch. I know I have one that is designed so that turning the switch to start does not power the starter solenoid. I requires a push on the key to do that. Not sure who the mfg is.
I had an issue with my ignition switch in which the mags were not grounded in the OFF position (switch was from Spruce, and made by a Spruce affiliate) and they swore up and down their switches NEVER have problems. They got it back and tested it and said it worked fine. I asked, and was sent, a new switch which worked perfectly with no other changes on my end.
I wouldn't trust the quality of those switches |
| All times are GMT -6. The time now is 04:07 PM. |
