Nicely done tests...well performed and documented. Thanks for the data and analysis!
Thank You!
... We wish to say thank you to Brian for all the work gathering and posting his information on our "EZ Cool Flaps". We know this requires a lot of work and we wish to say thank you as it helps us and others with this product. Allan and ASA staff...:D
RV7 installation
Hello,
I know it is an old post but I'm still trying... I would like to install EZ cool flap on my RV7. Do you have some pics about your installation ? Is it mandatory to install 2 cool flap or one is enough ? In advance thank you Sylvain |
http://www.vansairforce.com/communit...lap#post898136 I put in two and don't regret it. It looks symmetrical. Have no data on just putting one in. The only complaint I have had is the original hinge cracked in short order. |
Brantle,
Curious if you know the sevo?s recommended operating temp specs on the EZ-Cool flap? Also how many hours and if any servo failures? Thanks, Andy |
James cowl
Thank you for your reply. I read a lot of your posts when you installed yours 4 years ago..
I have some other questions : -Did you have some issue with the electric engine (with hot temperature ?) - Is there somebody who installed some cool flap on a St James cowl ? I think there is a thickness difference with the standart Van's Aircraft cowl.. -Is it possible to connect the cool flap on a VPX ? I already have some free switches on my panel, connected to my VPX.. In advance thank you Sylvain |
very first run of this product, we used an aluminum hinge that produced a few failures. We immediately converted to a stainless hinge that is several times stronger and thicker than the aluminum one. We have had no failures since the changeover (Over 2,300 units in service). These now have many thousands of hours in use, with very very few failures of the electronic actuators, and no mechanical failures. Most of the few actuators that needed replacement were due to the wires being pulled hard, damaging the unit. We have not seen any temperature related issues, but I still think it prudent to shield them from radiated exhaust heat when mounted in close proximity to the exhaust pipes. If so desired when installing, one can elect to use any DPDT switch to operate the EZ Cool Flaps that possibly fits your needs better than the supplied switch. Every aircraft is a bit different, but in general most people elect to install a pair of flaps, as you will never get too much cooling. One will usually drop CHTs by about 20 to 25 Deg. and two will drop things by 35 to 40 Deg. Unlike cutting the exit air cowl forward, or adding louvers that will be costly to your cruise speeds (sometimes as high as 10 Kts), you can have all the cooling advantages of cowl flaps with no downside. This is why virtually all certificated general aviation aircraft are designed and produced in this configuration. I hope I have satisfied your questions, and do appreciate your inquiry. Thanks, Allan..:D ..PS; Please keep an eye on our website as we have several new and exciting products coming very soon!..:D |
Mine are fed from a circuit on my VP-X Pro. I do not use the VP-X to control them, just to feed them power. |
| All times are GMT -6. The time now is 10:58 AM. |
