VAF Forums
-   RV Ongoing Maintenance Issues (https://vansairforce.net/community/forumdisplay.php?f=76)
-   -   O 320 Oil screen gasket ?? (https://vansairforce.net/community/showthread.php?t=11596)
John_RV4 10-09-2006 10:24 AM
I want to remove and clean the oil screen in my O-320. I think the gasket/seal is weeping a bit and I want to replace it.
However, I'm having a tough time finding the right part # so I can order some.
Does anybody know the part # for the screen gasket ??
Thanks in advance.
John
Mel 10-09-2006 10:30 AM
If you are talking about the suction screen the gasket # is STD-111.
If you are talking about the screen that is used instead of a filter, the housing gasket is 61173 and the circular gasket at the rear of the housing is STD-294.
Hope this helps.
John_RV4 10-09-2006 10:33 AM
Speed of light......
Geez Mel,
What took you so long :-). That reply took almost 300 milliseconds..
thanks
John
Mel 10-09-2006 10:44 AM
Sorry, I didn't have the manual handy. Guess I'll have to get the bookshelf closer to the computer.
John_RV4 10-09-2006 11:49 AM
I thought the rest was easy.......
I was looking for the 111 gasket. I tried Spruce, Wicks,Van's, SkyRanch....
Nobody seems to have it.
Got a source ?? Thanks again.
John
Mel 10-09-2006 12:17 PM
You might have to go to Lycoming or Surperior. Check with a local A&P. They have to get them somewhere. The suction screen should be checked at least at annual.
John_RV4 10-09-2006 12:34 PM
Chief
Chief has LYC 61173 "Oil Screen Gasket". I think that's the right part. They also have the screen at a mere $66. Sheesh !!
John
az_gila 10-01-2007 09:27 AM
Wrong number
John
Wrong part... that's the large paper gasket that is used for the oil screen - the oil screen on the accessory housing that Lycoming uses when a spin-on filter is not used.
gil A
Geoff 10-01-2007 11:22 PM
John
I think it's the same thing as an AN900-16 (MS35769-21). That's a copper-asbestos crush gasket. Try this link: http://www.aircraftspruce.com/catalog/appages/an900.php
I stole this information from another post on this forum: http://www.vansairforce.com/communit...39047#poststop
-Geoff
az_gila 10-02-2007 12:38 AM
AERO for parts
Originally Posted by Geoff (Post 158868)
I think it's the same thing as an AN900-21 (MS35769-21). That's a copper-asbestos crush gasket. Try this link: http://www.aircraftspruce.com/catalog/appages/an900.php
-Geoff
AERO is a good source for Lycoming parts.
Their web site is also good for giving alternate part numbers.
http://www.aeroinstock.com/products/...ail/index.html
Usual disclaimer... just a satisfied customer....
gil A
