VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   Help identify this connection type (https://vansairforce.net/community/showthread.php?t=115403)
NTex 07-18-2014 12:56 PM
Does anyone that works with electronics know where to locally get this part?
It's the pigtail lead to the 460 configuration module. Guess I had too much coffee and I used my strippers to cut the white wire vs. just stripping. I need a replacement, but I'm not sure what it's called. It looks kinda like a CPU fan or a SCSI connector, but it's not.
Garmin part number 325-00122-00. I'd love to pick one up at frys or an electronics store than have to order from garmin
Thanks in advance
Brantel 07-18-2014 01:00 PM
There are literally hundreds of thousands of different types/designs and brands of these type connectors. Finding the exact match can be easy and can be hard depending on how lucky you are.
If you buy one, it most likely won't have the wires attached.
I would just solder on a new extension piece and put some heat shrink on it.
NTex 07-18-2014 01:18 PM
Ah, good idea thanks!
Sam Staton 07-19-2014 04:51 AM
Connection type
This looks remarkably like the power connection from a 3 1/2" floppy disk drive (remember those ....).
Gary2418 05-01-2020 01:27 PM
Connector
Were you able to source this connector? If so can you tell me where, thank you.
Tankerpilot75 05-01-2020 01:36 PM
Try SteinAir’s website. It’s called a Moles plug. They’ve got different number of pin connections (2,3,4,6, 8, 12) available. They also sell then male and female pins. Check they’re website for several videos on how to wire things up using the various types of connections available.
fl-mike 05-01-2020 03:07 PM
sort of looks like a JST mini micro SH series. You might be able to find a mark on the housing.
https://i.ebayimg.com/images/i/25197...-1/s-l1000.jpg
bjdecker 05-02-2020 06:43 AM
JST SHR Series 4 pin
https://order.jst-mfg.com/InternetSh...wProductDetail
https://order.jst-mfg.com/InternetSh...=1&key=eSH.pdf
The contacts are what you're needing I think -- they are JST, SSH-003T-P0.2-H
https://www.digikey.com/product-deta...3-1-ND/5725854
B
NTex 05-02-2020 12:23 PM
Mike,Brian... I think you're right. Those look pretty close. Gary, I would check that out.
Originally Posted by Tankerpilot75 (Post 1426766)
Try SteinAir?s website. It?s called a Moles plug. They?ve got different number of pin connections (2,3,4,6, 8, 12) available. They also sell then male and female pins. Check they?re website for several videos on how to wire things up using the various types of connections available.
Tankerpilot75 - yes good call! Stein's a great resource for both materials knowledge. In this case, this is a pretty specialized connector. Those you linked to are Molex connectors, typically used for small current or sometimes signal wires. You'll see they (molex) are much larger than the ones in my photo.
Gary,
Blast from the past! This thread is about 6 years old... I think I ended up getting the part from Garmin. I looked into the manual and now it recommends doubling the wire connection since it's so thin.
PNLBLDR 05-05-2020 07:53 PM
In stock!
For anyone looking for this small part in the future..:)
https://www.steinair.com/product/gar...odule-harness/
