VAF Forums
-   RV-12/RV-12iS (https://vansairforce.net/community/forumdisplay.php?f=73)
-   -   What do you flight plan for cruise speed and fuel burn? (https://vansairforce.net/community/showthread.php?t=115158)
Top Cat 07-12-2014 06:50 PM
What do you folks use for cruise speed and fuel burn when planning a cross country in the RV-12?
I would really appreciate any and all experienced input, thanks!
Jetguy 07-12-2014 08:06 PM
Cruising at 3000'msl 5450 RPM 5.5 gals an hour.:) Lower RPM means lower gals per hour!
Top Cat 07-12-2014 09:04 PM
Thanks for the info!
So?one guy told me 5140 rpm (about 21MAP) produces 4.5 gph. That sound right? (for planning).
Thanks again.
bajapilot 07-12-2014 09:24 PM
Fuel burn
Can't give you much on cruise speed since I just made by first flight about a week ago but I have 1000 hours on the same engine in my other airplane and that burn sounds right.
I cruise @5000 rpm and get consistent 4.2-4.3 gal/hr. @5200 rpm, 4.6 - 4.8 gal/hr. @5500 rpm, 5.5-5.6 gal/hr.
The RV-12 is faster but WOT on both are about the same.
Bill
Top Cat 07-12-2014 09:34 PM
Thanks a lot Bill!;)
BigJohn 07-13-2014 05:39 AM
You will need to refine the numbers for your own airplane, and your cruising habits, because there are just two many variables to quote a "standard" number. For example:
Prop pitch, which affects RPM vs. MP ratio.
Desired cruise speed.
Cruising altitude.
The nice thing is, you can fly this engine/airplane combination at a wide range of power settings, depending on your mission that day. Going somewhere in a hurry? WOT at high altitude. Local sightseeing? Low power, low fuel burn, low speed.
f1rocket 07-13-2014 05:48 AM
I plan at 114 kts and 5 gal/hr. Prop pitch affects these.
plehrke 07-13-2014 08:07 AM
So…one guy told me 5140 rpm (about 21MAP) produces 4.5 gph. That sound right? (for planning).
Thanks again.
Look in the POH. Should be listed there after initial flight test determines the numbers for your aircraft.
RFSchaller 07-13-2014 12:30 PM
5100 RPM, 20-21" MAP, 110 KTAS, 4.5 GPH. Very consistent numbers for my plane.
Top Cat 07-13-2014 01:22 PM
I haven't picked my airplane from Vans yet so I don't have access to POH.
I appreciate the actual working numbers from experienced owners as I start planning flying trips. Thanks guys!
