VAF Forums
-   Propellers (https://vansairforce.net/community/forumdisplay.php?f=19)
-   -   CS Prop Installation (https://vansairforce.net/community/showthread.php?t=11500)
RVPilotDotCom 10-05-2006 12:20 PM
Can anyone tell me what special tools ( crow foot wrench size... whatever ) I will need to install my CS Hartzell prop? This is my first and those bolts are very hard to get to, I can't even imagine what it will take to get them to the proper torque.
- Jim
RV_7A 10-05-2006 12:30 PM
Jim
The easiest route is a flat torque wrench such as the one shown below. They come in specific sizes and torques. Heres a good link for some choices...
http://www.aztecbolting.com/index.htm
http://www.aztecbolting.com/pdf/CDIT...re-Set2005.pdf
-Jeff
or
robertahegy 10-05-2006 06:15 PM
An open end wrench will suffice to tighten the nuts on the prop hub studs. I cut off a section of an open end wrench and welded it to a 1/2" drive socket. Then I calculated with the extra length to get the corrected torque value needed to torque the nuts. Or buy the special tool from Hartzell for $350.00. Other than the Hartzell double crows foot, I could not find one long enough that would work. About a 3" section from a quality open end wrench welded to an impact socket did the trick for me.
Roberta
BReiter 10-05-2006 08:04 PM
Try Avery
Avery Tools has a handy Hartzell wrench attachment for $39.00. It looks the same as the $200+ from the prop manufacturer and even comes with a torque conversion chart.
frankh 10-05-2006 08:48 PM
weld on a socket
to and old 3/4" open end wench...Or wrench even!...:)
Works geat, its free but remember it WON'T be a "certified" weld...Very important that....:)
Frank
RV7a...hopw my prop stays on?
Davepar 10-06-2006 11:00 AM
Or the $2 solution. 3/4" combination wrench, bolt, washer, nut:
Nobody's mentioned it yet, but you should only finger tighten the prop bolts until the very end. If they are getting tight before the end, the prop isn't going on straight. You'll need to back off one or more and try again.
N130WN 10-06-2006 08:43 PM
Similar idea:
http://bowenaero.com/mt3/archives/20...e_adapter.html
Ironflight 10-06-2006 09:01 PM
I did mine just like Larry....Oh, that's right, I stole the idea from his web site! (Thanks Larry...)
Paul
RVPilotDotCom 10-07-2006 12:06 AM
Great ideas!
Many thanks to all who responded.
I'm sure with all these great ideas, I should have no problems getting the job done.
Clear skies,
- Jim
MCA 10-10-2006 12:52 PM
Torque wrench angle
An A&P friend told me that putting the torque wrench 90 degrees from the extension means that the torque reading is accurate and you don't need to do any calculations. If the torque wrench is parallel to the extension then you need to do some math.
Anyone heard anything similar?
