VAF Forums
-   GPS (https://vansairforce.net/community/forumdisplay.php?f=39)
-   -   GX55 Problems (https://vansairforce.net/community/showthread.php?t=11435)
chuck 10-03-2006 10:37 AM
GX55 Problems
I have a Apollo GX55 GPS that has been acting odd lately. It has been working without fail for about 1300 hours.
I don't get a nav solution for about the first 15 minutes of flying. It just sits there parked on KAAA with an indication that the nav is invalid. Then a bit later I look down and sure enough it figures out that I'm in Washington an acts normally. I've checked out the antenna BNC connectors and they are tight and corrosion free.
I'd like to swap out antennas and am wondering if any GPS antenna will work or just Apollo/Garmin GX antennas.
Any idea's would be appreciated. Thanks.
Norman CYYJ 10-03-2006 04:15 PM
Sounds like the internal memory battery is dead. This causes the unit to go through a complete cold start-up everytime you turn it on.
DeltaRomeo 10-03-2006 06:10 PM
My GX-55 stopped working when I filled it with water washing the plane :o .
If you pour about 4oz of water out of it...well, that's your problem <g>.
b,
d
Vern 10-03-2006 07:43 PM
Wet stuff...
Doug,
I remember that day when everything got wet when you and Jay picked up Flash from the painters! An 'advantage' of the tip-ups!
Best regards and keep her dry!
DeltaRomeo 10-03-2006 07:49 PM
LOL, yep...I remember that, Vern!
Then I 'fixed' the gaps with sealing strips and washed it a year later and more water got in! So, the *2nd* time I washed my GPS/Comm it stopped working <grin>. That was one expensive wash....
b,
d
Shine'r 10-04-2006 08:02 AM
Chuck it sounds like the memory battery inside the unit. This is a common problem after about five years of use. I had the same problem on my 820 and came to find out they stopped making the battery. I went to radio shack and found one that would work and wired it in. Garmin wanted $400.00 to replace the battery....
Shine'r
Sunny, Warm, Pittsburgh, Pa.
chuck 10-04-2006 09:20 AM
Thanks everyone!
Thanks everyone. I'll pick up a battery.
